performance problem after replacing distributor
Let me preface this post by noting that I don't know very much about cars so please use small words
My wifes 98 civic died last weekend and wouldn't start. We took it to the mechanic who verified that it was a bad distributor and replaced it. When I picked the car up to drive it home I noted that the acceleration was very 'mushy' especially at low speed (basically you could put the accelerator to the floor and it wouldn't do much of anything for 3-5 secs). Once it gets up to cruising speed it seems more 'normal' but still lacks that punch when you put your foot down. We've been driving it since midweek and oddly it seems to have semi fixed itself (its still sluggish, esp at lowspeed) but its much better than it was at first....curious no? So my question is, what could be going on here? And secondly, what kinds of things 'should' the mechanic have done after replacing the.distributor? Is there anything that must b tuned or calibrated after replacing a distributor? I want to be armed with some good knowledge before I speak to him again.
Many thanks in advance!
Re: performance problem after replacing distributor
he shouldve adjusted the ignition timing otherwise it would run as you described, like crap.
possibly the ecu trying to compensate by adjusting other things. not the right way to do it and it will never be perfect. it can even cause other problems eventually.
thana
Jun 15, 2020 07:05 PM
McD
Apr 16, 2015 10:46 AM
BREADFAN
Apr 15, 2015 08:58 AM
thesushiboy
Apr 12, 2015 02:54 AM
