97 Ex civic automatic Transmission Problem Need help
Old May 20, 2011
los0390's Avatar
los0390 is an unknown quantity at this point
So I got a 1997 Honda Civic Ex Coupe Automatic transmission and re-made d16 engine that was just put in. My problem is when i start my car and put it in gear it will go down the block with no problems till 5 mins later the trans slips and the rpm would just rev up and it wont move. When I turn off the car let it cool down for 5-10 min i start it up again and it will go back to gear and move forward like nothing happened but 1-5 mins later it slips again. Someone told me that i need to replace the trans but i need a second opinion.
Old May 20, 2011
lazlong's Avatar
Re: 97 Ex civic automatic Transmission Problem Need help
Check the fluid level in the tranny. Sounds like it was over-filled, which would cause the problems you're experiencing.
Old May 20, 2011
los0390's Avatar
when i got the car back after the engine was put in it was driving fine till 1-2 month later the slipping happened. Could it still be that its overfilled?? It does look like its overfilled i just checked it its over the mark. Someone also told me that i probably just need to change the fluid and transmission filter? What do you think about that??
Rinzlor
Apr 24, 2015 10:33 AM
alexkharden
Apr 23, 2015 07:13 PM
Richkid23
Apr 19, 2015 12:53 PM
Russps
Nov 8, 2001 02:00 AM
vexxed82
Bolt-on Engine Performance
Nov 6, 2001 08:00 PM
