Transmission trouble and suggestions..
Old Mar 30, 2011
svx crzy's Avatar
svx crzy is an unknown quantity at this point
I have a 2000 SI with a manual transmission. It seems to have lost 5th gear and reverse - I can't get it to go into either gear but 1st through 4th are all acting normal. Anyone else ever have this happen and what was the fix. If it needs a new transmission does anyone know which other model/year civic transmissions will bolt up.
Thanks.....
Old Mar 31, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: Transmission trouble and suggestions..
will it go into those gears when the car is turned off?
Old Mar 31, 2011
Kennykid2002's Avatar
Kenny the Ricer
Maybe you have something stuck inside the shifter o.o
It happens
Old Mar 31, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
turn off the car and put it in 5th and reverse
i have a 2000 si also, but with a diffrent tranny problem
it can be the shift fork inside the tranny that might have bent or somthing.
go under the car and check the shifter bushings can be wear out,
any b series tranny will bolt right up as long as they are hydro tranny
if u use gsr tranny you will have diffrent gear ratios
if u want the same gear ratio u have to find another b16a2 tranny
Old Mar 31, 2011
pull down the shifter boot and look down the shifter lever with a flashlight
somthing probly got in the way cuz 5th gear and reverse is to the right
some lose screw or coins might got in there
Old Apr 1, 2011
svx crzy's Avatar
Thanks for the suggestions - I plan to check it out this weekend. Will let you all know what I find.
SidCivic
44
Oct 12, 2017 03:39 PM
dust
Sep 20, 2016 06:39 PM
knknif
Aug 4, 2015 06:11 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
