97 EX 5 spd no power NEWB
Old Mar 3, 2011
ck82's Avatar
ck82 is an unknown quantity at this point
Unhappy 97 EX 5 spd no power NEWB
New to hondas my 4 door ex is really slow when you step on the gas seems like it will only start moving in high rpms what can cause this?
Also how can i tell which transmission i have it says S40 than some random numbers but no b000 or a000
Old Mar 4, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: 97 EX 5 spd no power NEWB
Your clutch and flywheel come together and the flywheel says " You will NOT spin as fast as me ". In other words, you need a new clutch and flywheel resufacing because the clutch is slipping to the extreme. That's my best guess.
Old Mar 4, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
smelling burnt clutch much? lol, like tbohar mentioned it sounds like your clutch has taken a crap on you and you need to replace it.
Old Mar 5, 2011
ck82's Avatar
clutch does not slip it just seems to rev really slow even when the pedal is all the way down then starts to pick up after 3500 rpms but still doesnt pick up fast
Old Mar 5, 2011
BlueEM2's Avatar
Whachya lookin at?
Okay then, clean your throttle body... these cars are natrually slow unless you actually noticed a difference from before?
Old Mar 5, 2011
MelJ's Avatar
Trance Addict
Lol. Yeah they are. Is the gas pedal sticking? That would be a sure sign the throttle body needs to be cleaned.
Old Mar 6, 2011
Dizz's Avatar
Dizz is an unknown quantity at this point
Check air cleaner.Run a can of Seafoam,1/3 can in the intake,rest in a full tank of gas.Seafoam can work miracles on these.
High Milage? Using oil?Oil been changed regular?
Have the spark plugs been serviced?Fuel filter?
Check Dist. cap&rotor for excessive build up on inside.
If high milage,and all this is OK,do a compression check.
Regards,Dizz
Old Mar 6, 2011
BlueEM2's Avatar
Whachya lookin at?
Here we go with the seafoam again.... a tuneup should be good enough.
Old Mar 6, 2011
MelJ's Avatar
Trance Addict
. I agree. Or an Italian tuneup to go along with it . My 94 Corolla behaves the way it did 6 years ago with a basic tune up....and that thing is reaching 160,000 miles.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
carid
Nov 7, 2015 01:46 AM
JDMnoob
Aug 2, 2015 02:38 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
