Please help
Re: Please help
if you removed and cleaned out the idle air control valve and its still doing it and there are no vac leaks try unplugging it see if the car stalls. Also use a can of throttlebody cleaner sprayed all along the intake manifold and throttlebody listen for a quick change in idle, if there is then you have a vac leak.
