Please Help!!
Old Feb 8, 2011
tt2481ss's Avatar
tt2481ss is an unknown quantity at this point
Please Help!!
I drive a 2000 Honda Civic LX, and have owned it since it was new. Tonight I was driving home doing about 40 mph or so, and my car just completely shut off. My lights in the dash that indicate what gear you are in went out. I tried to shift the gear, but nothing happened. When I saw I had apparently lost all power, I immediately put on my brakes, but it felt as if my brakes weren't really working. I did end up coming to a complete stop. I put the car in park & turned the ignition off. I then tried to restart it, and it started up perfectly & drove home. Does anyone have any idea what could have caused this? This was scary & dangerous, and I need help. Thanks.
Old Feb 8, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: Please Help!!
Check 2 things;
1) battery terminals make sure they are tight, clean and the chassis ground is tight and clean.
2) there are 2 philips head screws that hold the main battery wires in the engine bay fuse panel make sure they are tight.
Now also when it shut off did you hit a bump? If it happens again see if you can hear a click from the right hand side behind the glove box, smack the dash with your hand in that area see if the car loses power if it does then you have a faulty main relay.
Old Feb 8, 2011
Steven21's Avatar
Steven21 is an unknown quantity at this point
Re: Please Help!!
Its the ignition switch. I had the same problem and actually there is a open recall on these cars to get it fixed. Just go to the dealer ask about it and they'll do it up for you parts and all are free but i would avoid driving a whole lot cause that can be very very dangerous
