need help on my civic 93 pleasee!!!!!
Old Oct 10, 2010
chirby17's Avatar
chirby17 is an unknown quantity at this point
my car is bogging its a d15b jdm. it starts when i drive for a while, then wen i got home the car sounds really high like high idle. then wen i rev it its start to bogg like its struggling to get gas or somthing. then its dies, then i turn it on. i check the fuel injectors plug i took it out then it doesnt feel like its about to die but the other three does. its the first cylinder starting on the right. i dont kno if it have to do with this but smokes comes out of my tail pipe like blue or white smoke.i cant tell. and i check the spark plugs it does the same thing. but wen i start it up wen its coool and i take off the plugs and the fuel injectors plug (not the same time) then it acts normal, like its about to die but the other three feels like its about to die more. please help thanks
Old Oct 10, 2010
lazlong's Avatar
Re: need help on my civic 93 pleasee!!!!!
With smoke out the pipe it sounds like the headgasket. Check for milky looking oil, bubbles in the radiator, oil leaking around the heads. Then you can have it tested for exhaust gas in the coolant as well as a compression test for the cylinders, that will tell you if it's the headgasket.
Old Oct 10, 2010
chirby17's Avatar
help
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
