need help 1998 civic ex
Old Sep 13, 2010
meeko's Avatar
meeko is an unknown quantity at this point
Unhappy need help 1998 civic ex
first let me start with the car was running just fine (1998 civic ex, 2 door 4 cy, d16y8, I decided to do some maintenance to it since i just bought it ( has 133000 miles) replaced fuel filter,started it up, started fine, checked for leaks no leaks, then replaced the rotor, cap, and wires, went to start it up, started for 3/4 seconds then it turned off, wont start, check for spark, it appears to have no spark, checked all ignition fueses,there fine, i thoght could it be the coil, could it be the module, before i start spending money, both parts are very expensive, can anybody point me in the right direction, any help i would greatly appreciate. one more thing when it started i had the lower part of the airbox off, woldnt think that would affect it to start, i also noticed when i check for spark, the plugs were some what wet with fuel.
Old May 15, 2011
cfd457's Avatar
cfd457 is an unknown quantity at this point
Re: need help 1998 civic ex
Did you ever get your civic fixed. I seem to have the same problem. Not wanting to spend money on parts that are working and not knowing which part is bad
Old May 15, 2011
MelJ's Avatar
Trance Addict
This topic is almost a year old.
Spark plugs with fuel foul usually= flooded engine. Been there, done that. Buy a new set, let cylinders air out. Put new plugs in. Start car with gas pedal floored and it should push any remaining fuel out.
Hrddrvs
Apr 11, 2015 11:22 PM
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
