1998 Honda Civic
Old Dec 26, 2009
cycho's Avatar
cycho is an unknown quantity at this point
1998 Honda Civic
Hi there
I have a 1998 Honda Civic 2 door coupe. It has a radiator problem???
The temperature in the car is always high, the needle always goes to H even if I go for a mile distance. The heater is not working in my car from a couple of days.
What might be the reason for temp to go high??? Is it thermostat or radiator cap or radiator itself????
and why is my heater not working????? .
what shud I do now??
Can anyone help me with these issues.
Thanks in advance
Old Dec 27, 2009
fatsheep's Avatar
fatsheep is an unknown quantity at this point
Re: 1998 Honda Civic
Originally Posted by cycho
Hi there
Thanks in advance
Check your coolant reservoir. Is the fluid between the max and min lines? Is your radiator fan working? Thermostats are pretty cheap so you could try replacing it and see if that helps. Sorry I can't be of more help.
Old Dec 27, 2009
BlueEM2's Avatar
Whachya lookin at?
Sounds like you have problems with your heater core, or you could be very low on coolant. Any leaks anywhere that you have noticed?
jessicakaybby
Apr 20, 2015 12:11 PM
