Electronics Post information/questions/Issues about Electronic parts here.
DRL Warning Light
Old 02-03-2019
drourke's Avatar
drourke is an unknown quantity at this point
DRL Warning Light
I have a 2010 Civic Sport Sedan and I replaced my high-beam and low-beam bulbs with LED that I had brought in from China. All the lights work and the Daytime running light are on, but the DRL warning light is on and kind of flashes intermittently. They are the correct bulbs for my vehicle. (9005 & 9006) The running lights do not weaken in intensity, so the warning is not because the bulbs don't work. Has anyone had this issue? Could it be an in compatibility with the bulbs?
Old 02-03-2019
Prelude Owner
GolNat's Avatar
Re: DRL Warning Light
The new bulbs have a different resistance so the computer may think something is wrong when there really isn’t.
Old 02-04-2019
drourke's Avatar
I was thinking it might be ok. I was going to ask the next time I was in for an oil change. Maybe they can turn off the warning light. Thanks!
Old 02-04-2019
Incorrect resistance.
Simplest solution: Put the correct bulbs back in the high beams and warning light will go out.
No, the warning light cannot be turned off with a scanner.
Old 02-04-2019
Prelude Owner
GolNat's Avatar
You will need something like this to trick the computer.
https://www.vleds.com/r2-drl.html
Old 04-23-2019
Received 1,442 Likes on 1,198 Posts
Not a Helpful ho-to-do it step-by-step article, rather a help me thread.
Moving out of the DIY section.
Jasdip
Lighting
08-08-2006 06:03 PM
thomusvoo
Lighting
03-18-2004 07:37 PM
scatman
Lighting
02-02-2004 10:49 AM
TommyC225
11-06-2002 11:50 AM
Jeff
06-26-2002 03:01 PM
Quick Reply: DRL Warning Light
