View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
#2012
Re: WTF is this engine?
A Japanese car? Some other country?
You would really need to get the actual code stamped on that particular block, so we all might get to find out what it is.
All you have is a blurry ebay picture and a seller writing up whatever he wants you to read.
FWIW it doesn't really even have to be for a car at all. Could be an industrial engine for all we know.
#2016
Super Moderator
Received 1,853 Likes
Rep Power: 196 Re: Can these gauges work?
If you have a circuit diagram, 12V power supply, and a micro-controller you can give the cluster a fake speed signal pulse and run the miles/km up yourself. That is as long as that cluster works in a similar way to a stock one and it currently reads less than 380,000 km.
#2017
Can a misfire cause engine damage?
Just wondering what the long term effects of driving with a dead cylinder are. The cheap redneck that I bought my Dodge Stratus from unplugged the fuel injector and ran that car on 3 cylinders with a bad coil for 2 years. He knew that the coil was bad, he was admittedly too cheap to buy one. That car ran fine once I replaced the coil. But my question is does driving with a dead cylinder cause damage if you unplug the fuel injector, or does the engine just run like crap?
#2018
Re: Can a misfire cause engine damage?
How would a dead cylinder cause the catalytic converter to be seriously damaged?
#2020
#2022
It will make all your babies be born naked.
[shudder]
[shudder]
#2023
If it runs fine now, it runs fine now. Drive it.
If it didn't run fine, that would be a problem. Figger it out and fix it.
#2025
So it did not die because of the coil issue or injector issue?
FYI, FWIW, most (or maybe all) auto manufacturers' current failure strategy for engine single cylinder misfire is to turn off the fuel injector on the offending cylinder so as to not ruin the cat.
You tell me if you think a manufacturer would do that if it hurt the engine....
Honda can even shut off an entire bank on V engines for some fault issues.
Honda has several engine designs that turn off or disable cylinders for various economy reasons as part of normal driving routines.
#2026
#2027
The intent of the fuel injector shutoff strategy is to prevent damage to the cat.
#2029
One of my old cars lost a coil pack (2 dead cylinders out of 4, 1990 GM Quad 4 engine).
I followed the car as my kid limped it out to the shop at night.....The cat was screaming nuclear bright yellow under the car lighting up the road.
I really hoped it would light the carpet on fire and burn to the effin ground so I wouldn't have to fix it.
#2030
#2031
The idiot snowflake teenager (20something) with entitlement issues who already knows everything (far more than I) should have unplugged the injectors.
Maybe if I had diagnosed it from the other side of town in the dark over the phone.
All I knew was the kid said the car would barely run and he left it where it was. I drove him to the car then followed it to the shop.
#2032
#2033
Received 1,442 Likes
Rep Power: 338 Re: Can a misfire cause engine damage?
go take your medicine
#2034
What causes bent valve stems?
My neighbor has a 1992 Civic with a D16Z6 engine with 380,000 miles that blew the head gasket. He pulled the head to change the gasket, and he offered to pay me to go through the head to ensure that it wasn't warped, and also to do a valve job, change the valve seals, and clean everything since admittedly every time he tried to do internal engine work, it ended in a disaster. So I rebuilt the head for him, but as I was regrinding the valves, I noticed that 3 of the valves had bent stems. The stems were bent enough that I had trouble pulling the valves through the guides, and there is a shiny spot on 2 of the valves where they were rubbing on the guides, so I replaced the damaged valves with spares I had. He has owned this car since it was new, and it has never broke a timing belt or been abused. Anyways, when he drove it for the first time since this work was performed, he called me to tell me that the car hasn't run that good in many years, and he was really happy with the work I did. Apparently engines run better when valves aren't bent. So what could cause the stems of the valves to bend? Neither one of us can figure that out. Any ideas?
#2035
Re: What causes bent valve stems?
#2036
The E85 experiment
So I got bored, and if you don't already know, me being board can be a very dangerous thing. But nonetheless, I became curious what would happen if I add E85 to the gas tank. I added around 2.5 gallons of E85 to my car's 13 gallon tank, which was nearly full. And not much happened. I initially didn't notice anything, but after a few minutes, the fuel trim became a bit less negative. It was about -20 to -25 before, but now it's about -15 to -20, which makes sense because ethanol has a lower energy density. I imagine the fuel trim would go slightly positive if it was close to 0. As far as power, I honestly don't know if there is any change since I was stuck in traffic on the way home, so I couldn't floor it. There may be a slight improvement in low end torque, but I can't say for sure yet. I'll update you after I drive more and when I try to use a higher concentration of ethanol.
And yes, I know that this isn't a good idea and that the fuel system isn't designed for E85, so no need to tell me.
#2037
Re: The E85 experiment
#2040
Re: WTF is P1713?
These come to mind, take your pick:
Not a code written for N.A. market cars
Code written only for use in other markets
Code reader is lying to you
I will automatically assume the JDM PCM and harness does not match the trans you have in your car and is yet another reason you should have just gotten the correct parts for your car the first time.
