i want some boom boom
Old Jun 16, 2003
Dimplebutt's Avatar
Dimplebutt is an unknown quantity at this point
Talking i want some boom boom
hey gusy i was drivign around when all of a sudden my sub stopped workign. the amp is on and i can hear some high's but there is no bass. all the connections with the amp and the box look good. is there anything that you think might be wrong?
Old Jun 16, 2003
GrimNexus's Avatar
GrimNexus is an unknown quantity at this point
is your amp wired to both your comps and subs?? or do you have 2 amps, your comps wired to one, and your subs wired to the other? if you have your subs wired to a different amp, then the amp powering your subs probably overheated. let it cool down and try it again later.
If they're wired to the same amp, make sure that all your wires are still connected and everything is working properly.
Normally when a sub would be broken, it either smells really bad, sounds really bad, or sounds pretty distorted.
Old Jun 16, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
or like one i had, it locks down all together...
Old Jun 17, 2003
Dimplebutt's Avatar
well it's just one sub with one amp and there's no bad smell everything is connected.
Old Jun 17, 2003
GrimNexus's Avatar
most probably a problem with the amp, see if you can swap it out with another amp to try the sub with something else.
or get a DMM digital multi-meter or something like that, it measures voltage and other various things...
Old Jun 17, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
You could have had an RCA disconnect from the back of the headunit, or one of the wires inside the box could have disconnected.....you could have a broken connection in the amp. Another possibility is a problem with your sub....I had that happen to both of my old W3's, it just stopped playing....the voicecoils were cooked, but there was never any smell or anything.
Old Jun 18, 2003
Dimplebutt's Avatar
thanks for all the help i'll check my rca connections on the Hu and then if it doesn't work i'll check out the wires in the xub box. and I'm pretty sure it's not the amp but i'll try that too thanks
Old Jun 18, 2003
gotti's Avatar
Maybe ya blew them...thats what happened to me
Old Jun 25, 2003
Dimplebutt's Avatar
thanks for all the help but the sub is blown. my friend gave it to me like 2 years ago and he had it for like 5 so i think it was used well. I took out the sub and put 6 x9 in with the gain down and the 6x9 worked. so the sub is gone. well thanks for the help I'm looking into getting the Adire audio shiva in a sealed box. probably in a month or so. anyone in so cal have one? can i hear it sometime?
Old Jun 26, 2003
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
you probably blew the sub. It happened to me a few days ago. I had a cheap jbl 10 with a 150 watt amp that wasn't even turned up a whole lot cuz i didn't want a lot of bass. I was jammin to 50 cent on the radio and then it made a wierd thump and just quit workin. Oh well, I didn't really care. Just get a new sub.
jpat21
Sep 3, 2015 11:32 PM
Rufus
Arizona
Dec 26, 2003 07:38 PM
ImPulse
Mid Atlantic
Aug 7, 2003 12:31 PM
