Amp Doesn't Turn On
Old May 15, 2003
salokod's Avatar
salokod is an unknown quantity at this point
Amp Doesn't Turn On
Well, one day I'm cruising, and my subs turned off... It was weird because then like 5 minutes later it would turn on. So this kept going on for like 2 weeks. I thought maybe it was the power wire, and I messed w/ that for a while.
If they cut out for a long time, I would just shut off my car for like 2 minutes, then turn it on, and they would work.
Then they just stopped.
I got out my test light, and the power wire has power going to it, but the Remote Start doesn't anymore. So I pulled out the console and the remote start was hooked up right. Is it possible that the CD player just messed up in that spot, or if that were to mess up would the whole thing mess up? I'm so confused.
I've tried anything, any suggestions?
Old May 16, 2003
Ed's Avatar
Ed
Are the subs wired correctly? Is the amp warm? is there a protect light, does the LED still glow green when it goes out?
Old May 16, 2003
12W6v2's Avatar
12W6v2 is an unknown quantity at this point
test the remote wire behind your cd player to see if it has power. If so, then its not your cd player. then look to see if your amp is on when your sub cut off. if so, then your wiring for the sub is wrong, or something is wrong with your amp.
Old May 16, 2003
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
dude, do what 12w6v2 said then check the ground wires, and make sure your not overloading your amp...
Old May 16, 2003
DizWikedCivic's Avatar
how many amps did you hook up to your remote wire, did u hook anything else to it, if you have did you had put to much load on the remote wire, shouldve use a relay
Old May 16, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
check your ground wire. also did you sand down the paint to bare metal where you grounded it.
Old May 16, 2003
outdrsmn80's Avatar
outdrsmn80 is an unknown quantity at this point
Check the Remote Power turn on...if there isn't power to it at the amp, but there is at the HU, then the wire might have been rubbing on something and could have sliced. That would explain the cutting off
Old May 16, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
A lot of times the remote wire itself has a small 0.1 Amp or so fuse in it. Usually really close to the HU, like within 6" or so.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
dinsum
May 28, 2015 09:30 PM
WLakers
May 4, 2015 06:23 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
GhettoCivic
Nov 12, 2001 03:15 PM
