Speakers, Subs, Amps...
Old May 13, 2003
PimpLikeShrimp's Avatar
PimpLikeShrimp is an unknown quantity at this point
Question Speakers, Subs, Amps...
Yo wuttup. i just got a new 2k3 civic EX and i was wondering if the speakers in the back were 6 X 9's or not because i had 6 X 9's in my old car and the ones in the new civic dont hit nearly as hard as my old speakers.. also i was wondering what kind of subs or amps should i consider looking at cuz im gonna hook it up w/ a new system pretty soon. n e ideas or suggestions would be helpful.
Old May 13, 2003
hahaha its me again...... i was wonderin also about a "fox whistle" i wanna install on my car. its just an alarm siren that needs to be mounted in the engine bay, routed to a button in the **** pit and then back to the battery.... although i cannot find any good places to mount it or ways to run the wires through. if anyone knows how to basically install an alarm and run wires from the engine to the dash i would appreciate it if you replied. i like to run it to the center console.
Old May 13, 2003
VNlilMAN's Avatar
The Standard One
whussup pimp...
coupes are 6x9s sedans are 6.5s... fronts are 6.5s for both. you can see the rear speakers by opening the trunk and looking at the top.. as you can see they're cheap paper pioneers..
i might have my 1000wrms 12" fosgate power hx2 for sale.
the booty call i can wire it up for you, its easy... to make it sounds like a fox whistle i think you need a siren that sounds like it. a regular alarm one wont do
Old May 13, 2003
R2FRESH's Avatar
R2FRESH is an unknown quantity at this point
6x9's in the rear everyone knows its a bitch to put in becuz of the size of aftermarket magnets, they will rub against the trunk support bar, the only way like many do it is get different supports or take the stock ones out completly, good luck!
Old May 14, 2003
VNlilMAN's Avatar
The Standard One
depends what speakers you use. i heard you can get most to fit my adding spacers and bending those trunk springs a little
UltraHDGames
Jun 8, 2016 05:16 PM
Gsxtacy
Sep 12, 2015 01:09 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
redcloud
Sep 7, 2015 01:45 PM
