speaker rings at the back of the door panels
Old Apr 13, 2003
CivicFerio's Avatar
CivicFerio is an unknown quantity at this point
i took mine off... and i';m still hearing this vibrating sound.. any idea where it's comming from.. and o yeah..i put dynamat on my door.. and should i take the panel rings at the rears too? and do you think it will acutally make the vibrations worse if i cut those rings off?
Old Apr 13, 2003
WhiteRabbit's Avatar
you gotta play music that cases those vibrations most, then stick yrou ear in every nook and cranny of yrou car, searcing for all the rattles and resonances.... then you can kill them, one at a time.
when you got them all, turn the volume up some more and start over
Old Apr 13, 2003
CivicFerio's Avatar
um. how do i eliminate the vibrations if it's coming from the door panel? i think its coming from there
Old Apr 13, 2003
deadener on teh inner metal, padding between the skin and door, and spray undercoating on teh inside of the outer panel sprayed on through the door holes. (dont forget to cover up yoru windows.)
Old Apr 13, 2003
CivicFerio's Avatar
where can i buy this undercoating.. what does it look like? what do you mean by the door holes? the little holes that the door clips go thru?btw, i just put a 1sq of deadener around the door speaker. thanks WR!
Old Apr 13, 2003
yup through those little holes, they come in cans, you can get them at any automotive store, i think at circuit city too maybe
Old Apr 13, 2003
LudlamTheory's Avatar
i boogie for the raindrops
walmart has it. cheap 2 dollar a can version or 4.50 a can 3M brand
Old Apr 13, 2003
CivicFerio's Avatar
what can do i look for? i mean what kind of spray is it?
Old Apr 13, 2003
rubberized undercoating spray
Old Apr 13, 2003
CivicFerio's Avatar
thanks alot! u guys are great!
Old Apr 14, 2003
CivicFerio's Avatar
hey ludlam/wr i can't find any rubberized undercoating spary.. i tried everywhere! walmart, circuit, home depot,pep boys even target!.. all i saw was the adhesives..
Old Apr 14, 2003
its in the auto parts section of walmart
Old Apr 14, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
i used that yellow spray foam, works great. i think the name is "GREAT STUFF" used for like sealing leaky PVC pipes and stuff.Great for little holes, fills em up nicely
Old Apr 14, 2003
CivicFerio's Avatar
thanks.. i already went to the other wall mart.. i bought 2.. do you think it's a good idea to spray this thing under my tire well and the underbody?
Old Apr 15, 2003
thast why its called UNDERcoating! just dot get overspray on yrou windows!
Old Apr 15, 2003
CivicFerio's Avatar
hehhe!
hey i thought i just have to put a deadener(mat) on the metal panel and just put the rubberized undercoating at the inside of teh door panel? why do i have to worry about the windows since i will remove the outer panel?
Old Apr 15, 2003
because overspray will get rubber on yrou windows, i dont think you want to do any black polkadot tinting.....
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
timpan
May 18, 2015 07:06 AM
MamaBear2015
May 3, 2015 02:17 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
BabyLX
Nov 8, 2001 09:25 AM
