Wiring question? Help ASAP!
Old Mar 18, 2003
01ExSiLvErBuLLeT's Avatar
01ExSiLvErBuLLeT is an unknown quantity at this point
Dude i am sooo pissed....i connected sum bumper lenses to my car by tapping into the blinker lines but now whenever i turn my headlights on the dashlights dont turn on and just a little while ago i noticed that when i turn on the lights the blinkers and brake lights dont turn on...meaning that the only lights that turn on are my headlights and everything else is off...what do i do?
Old Mar 18, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
Fuses
Start checking the fuses.
Under the hood and the ones inside.
If it blows again you have a short somewhere in the wiring.
Old Mar 21, 2003
CiViCrAcEr2003's Avatar
CiViCrAcEr2003 is an unknown quantity at this point
make sure that you have everything grounded right and that you have the positive going to the positive wire and the negative to the negative. Check the fuses and make sure that none of your wires are touching each other someplace. I messed up a ton of the lights in my car when I installed my Cold air INtake and it was all because of ONE ground wire.. kinda crappy! just go over everything and make sure that you do it right!
Old Mar 21, 2003
Dr5D's Avatar
what your saying dosent sound like fuses. maybe wires hooked up in wrong places??? thats my best idea
Old Mar 30, 2003
zero2seven's Avatar
zero2seven is an unknown quantity at this point
are you sure that you tap the right blinker wire? But definitly sounds like a bad wire somewhere
juror
Jun 9, 2015 02:15 PM
pincookie1
May 4, 2015 12:22 PM
viper775
Dec 9, 2001 10:52 PM
CiViCPrAnInG2k1
Nov 27, 2001 12:07 PM
klam
Nov 16, 2001 03:36 PM
