MTX 18000D amp question.
Old Feb 28, 2003
bobbyd's Avatar
bobbyd is an unknown quantity at this point
I am getting one of these amps and was wondering if my electrical system will be fine? I have a red top optima battery if that helps? Will I need to upgrade anything to install this amp? Thanks guys!
Old Feb 28, 2003
Cyko's Avatar
Cyko is an unknown quantity at this point
Yer gonna need to tell us more. What else do you have installed.
Any other amps? What kinda gauge wire you have running to any
current amps you have? Will you be running a new wire for the amp
or be using the pre-existing?
Old Feb 28, 2003
bobbyd's Avatar
Quote
[hr]Originally posted by: Cyko
or be using the pre-existing?[hr]
Sorry about that.
Not sure what speaker I will be running but most likely either 1 or 2 mtx 8000 thunders. I plan on running 1/0 wire with a 150 amp breaker.
Old Feb 28, 2003
alex053's Avatar
Your gonna smoke those 8000's unless they are 15's. I used to work for MTX......I would upgrade you battery at a minimum and run at least the 9500 series woofers..if not then run at least 8000 woofers.
Old Mar 1, 2003
bobbyd's Avatar
Whay would that amp hurt those subs? Thanks
Old Mar 1, 2003
alex053's Avatar
because those subs are rated at like 400 rms each and your going to be putting like 800 watts to each. I have taken many calls on people with that same setup and blown subs.
Old Mar 2, 2003
slowlx2k2's Avatar
slowlx2k2 is an unknown quantity at this point
HEY ALEX I THINK i TALKED TO YOU ONE DAY AT MTX. I called and someone called me back. I think it was you. or could have been a guy named jeremy. at any rate if you are gonna do 8000's then do at least 3. if not those subs will not last. that amp has some serious nuts.
Old Mar 2, 2003
alex053's Avatar
Quote
[hr]Originally posted by: slowlx2k2
HEY ALEX I THINK i TALKED TO YOU ONE DAY AT MTX. I called and someone called me back. I think it was you. or could have been a guy named jeremy. at any rate if you are gonna do 8000's then do at least 3. if not those subs will not last. that amp has some serious nuts.[hr]
If you did it was about 6 months ago....im over at Rockford now
h4ldol
Apr 24, 2017 08:16 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
