Please Help..............
Old Feb 24, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Wiring Spkrs/Passenger Side?????
Hey everyone, im going to wire up my own component system in my civic to an alpine 2ch amplifier in the trunk of my civic and I know how to do all the wiring, but I am not sure about the passengers side. There is a panel right above where the passengers feet go and I need to remove to to get access to the gormet that goes in between the car and the door with all the speaker wires. How do I remove it?
Old Feb 25, 2003
doubledeuce2k2's Avatar
you mean the piece right below the glove box? there are 2 clips on the front of it, so you just yank on the front of it, fairly evenly because it is weak plastic. that piece pulls down fairly easily, then you pull the flap forward, as is merely held in place by a rod through a metal loop in the back. all the pieces to the right of the passenger's feet just yank off, so i assume this is the piece you are talking about.
Old Feb 25, 2003
ZSKCivic01's Avatar
Extreme Member
thats the piece, thanks for your help!
