changing the front speakers for sedan
Old Feb 17, 2003
CivicFerio's Avatar
CivicFerio is an unknown quantity at this point
i want to change my front speakers but i cant figure out how to take the side panel off.. the diy here is diffrent.. can someone help me
Old Feb 17, 2003
LiKEaFeRiO's Avatar
Pop off the bottom plastic piece from the the door handles and there should be 2 screws.
Remember that there are wires to unhook for the powerwindow button.
Next use a small flathead to pull out the square plastic piece behind the door latch. There should be 1 or 2 screws.
Take out the screws and separate the latch piece from the rod.
You should be able to just snap everything off.
Pull the bottom out then tug upwards.
Just be careful not the break the door lock piece like I did.
The area near the windows and sails are a little tough but dont worry about it.
That should be it.
Old Feb 17, 2003
fonto's Avatar
The LA Clipper
What's a Ferio anyway? Juss curious [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 17, 2003
LiKEaFeRiO's Avatar
Civic Ferio RS
Japanese Civic submodels
Old Feb 17, 2003
CivicFerio's Avatar
thanks likeaferio!
how do i pop off the bottom plastic piece? do i just pull it?
btw, the civic RS has body kits and has a diffrent grill.. but all civics from japan are called civic ferio(all 7th gen civics there are sedans)
Old Feb 18, 2003
fonto's Avatar
The LA Clipper
Quote
[hr]Originally posted by: LiKEaFeRiO
Civic Ferio RS
Japanese Civic submodels[hr]
Thanks...I always wondered what that meant [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 18, 2003
LiKEaFeRiO's Avatar
Just pull it out
theres a slot in the bottom where u can insert a flat head I think.
Has been a while since I took then apart
Old Feb 18, 2003
CivicFerio's Avatar
ok... thanks again!
Old May 21, 2003
orion_squall's Avatar
what do you mean by "door lock piece"?
the little thing we pull up when we unlock the door?
PimpBot5000
Nov 26, 2001 07:15 PM
ademarco6
Nov 16, 2001 10:19 PM
BabyLX
Nov 16, 2001 05:53 PM
ademarco6
Nov 12, 2001 06:52 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
