ok difficulty with amp need help
Old Feb 10, 2003
coolness5545's Avatar
coolness5545 is an unknown quantity at this point
ok i hooked up my amp, but for some reason when i acclerate u can hear it through my amp and when i step on my brake my speakers click. have no idea what i did to make it do this, but i was hoping someone might have had the same issue and solved it.
thanks,
chris
Old Feb 10, 2003
LudlamTheory's Avatar
i boogie for the raindrops
VERY common issue... called alternator whine
try this
1 - make sure your rca's and speaker wires are AWAY from your power wires...
2 - check your ground to see if it is securely installed and the area is sanded down
3 - if all else fails, congratulations, youre the new owner of an "audible tachometer"
Old Feb 10, 2003
Falcon's Avatar
Falcon is an unknown quantity at this point
Quote
[hr]Originally posted by: LudlamTheory
congratulations, youre the new owner of an "audible tachometer"[hr]
ROFL.. its the newest thing.. everone wants one
just like a whistle tip [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
but this might help you
1. run power wires up the LEFT side of the car if you are using the stock speaker wires (yes i said left.. simply cause the stock speaker wires run up the right)
2. run RCA's through the center console... so that you can avoid runing them through the dash at all (the only wire it will ever come close to is the fuel sensor... i think.. maybe the brake lights ect. run through the same loom.. i cant remember)
3. if rewiring all speaker wires, run them up the left side of the car (and then obviously power up the right)
Old Feb 10, 2003
doubledeuce2k2's Avatar
also see if you ran your RCA's by the fuse box under the steering wheel. move the wires near there and see if that helps (it did for me). and also move the wires behind the HU and maybe you'll get lucky (also has worked for me)
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
