S10L5 Sub Enclosure (Dimensions??)
Old Feb 7, 2003
noahnoah's Avatar
noahnoah is an unknown quantity at this point
This may be somewhat complicated to answer but I'm trying to figure out some dimensions for building a box for 2 L5 solobaric 10s. I'm not looking for anything souped up or jazzy just a plain ol box. I've built boxes before so everything else besides figuring out the dimesions of the box (which my brother usually did) I can do. Does it matter if there are seperate chambers for each sub or not? Even if someone has a dimensions for just one sub, I'll make two boxes it doesn't matter. I can do simple math but the size of the cone and all that stuff throws me off. I'd appreciate it if anyone can help.
Old Feb 7, 2003
666's Avatar
666
666 is an unknown quantity at this point
I've always built my boxes seperatly chambered, it probably does not matter this way but it's always the way I have done it. As far as the dimensions go, to find cubic feet multiply your heightXwidthXdepth (in inches) and divide that number by 1728. This will give you cubic feet. Example: 13"X12"X15"=2340 Now divide 2340 by 1728 and you get 1.354 cu.ft. If you knew what Kicker recomends for a box size you could now figure it out.[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Feb 7, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
I would say put both in a separate chamber so that if one blows the other will be ok.
I would go sealed ......
L5 10" requires
Small box = 0.66 cu ft = 1140 cu in
Large Box = 1.0 cu ft = 1728 cu in
Box for 2 speakers .....
1140 * 2 = 2280 cu in
1728 * 2 = 3456 cu in
So anywhere from 2280 cu in all the way to to 3456 cu in will work.
The trunk is about 40" wide x 15.5" tall ...... towards the front of it.
Based on using 3/4" MDF I would go with a box with OUTSIDE dimensions of:
- 9" deep
- 14" tall
- 36" wide
Take out the thickness of the wood, 0.75" from each end .... so 1.5" from each dimension.
This will give you an internal volume of 3164 cu in and should fit quite nicely.
Internal space: 7.5 * 12.5 * 34.5 = 3234 cu in
Separator: 7.5 * 12.5 * 0.75 = 70 cu in
Result Airspace: 3234 - 70 = 3164 cu in
Working backwards ..... you get 0.9 cu ft per speaker ..... perfect for what they recommend.
3164 cu in = 1.831 cu ft
1.831 cu ft / 2 speakers = 0.9155 cu ft per speaker
Also since the speaker depth is just under 6" ..... 7.5" inside is more than enough room.
Good luck ... and be sure to keep all your fingers and toes.
Old Feb 8, 2003
noahnoah's Avatar
thanx guys, I'll let u know what happens. Doesn't sound too difficult...
Old Feb 10, 2003
BlueStepSide's Avatar
BlueStepSide is an unknown quantity at this point
hey man i would give those subs about 1 cube each...i have talked to many kicker reps and they said for the 10's that they recommend 1.25 cubes sealed for each sub...i will be installing my L5's with about 1 cube each in a few days so u can wait an di will let you know how they sound if u want.
emiixo
Exterior
Sep 22, 2015 03:53 AM
Jrosa
Sep 14, 2015 08:24 PM
redcloud
25
Aug 12, 2015 01:23 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
