Amp Setting?
Old Jan 26, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Amp Setting?
Hey everyone, I just recieved my amplifier and installed it today with my sub and got it all working. I have a JL Audio 12w3 w/ Alpine MRD-M300 as my system. The M300 has 10 settings and I don't know what most of them mean so I am guessing I can get my sub alot louder and get it to sound better, since I haven't really tampered with the amplifier. I was wondering if you all could help me with the settings to get my sub sounding its best:
1. Input Mode - 1ch or 2ch? 0dB/ -6dB?
2. Low Pass Filter - On or Off? 30-200Hz?
3. Subsonic Filter - On or Off? 15Hz-50Hz?
4. Parametric Equilizer - On or Off? 30Hz-160Hz? Width 1 or 3?
5. Bass Compensation - On or Off?
6. Time Correction - On or Off? 0ms - 10ms?
7. Phase - 0/180?
8. Safe Mode - On or Off?
9. Memory - Write mode Yes or No? Read Mode Yes or No?
I hope you all understand this. These are all the options under each option. I would really appreciate your help. Thanks!
Old Jan 26, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
1. select 1 channel if you have one rca for the subs signal and 2 channel if you have 2 rca's for the subs signal
2. definatly put the LPF on look up the specs on your sub and see what frequencies its capable of. i have my LPF set at 125 hz
3. On, used to stop the sub from wastin power trying to reproduce frequencies that it cant make. neccesary if your using a ported box.
4. No clue
5. probably a bass boost feature, play around with it and see waht sounds better.
6. used if you have a time delay problem because of wiring length. you shouldnt need this feature.
7. used if your subs are wired in reverse phase. experiemnt with each setting and see which one sounds better.
8. not a clue
9. write mode is used to save your changes, read mode is when you cant make changes
Old Jan 26, 2003
ZSKCivic01's Avatar
Extreme Member
The input I don't understand. When you say one or two RCA is what im getting confused on. Front my HU to the amp, I have I guess one RCA, just red and white that hook up to the amp.
Old Jan 26, 2003
since you have two physical rca plugs, its 2 channel. the red rca is one channel and the white rca is another channel
twd000
Oct 4, 2015 12:52 PM
thaler4cuse
Sep 7, 2015 08:25 PM
redcloud
Sep 7, 2015 01:45 PM
redcloud
25
Aug 12, 2015 01:23 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
