Amp cutting out. Help Please.
Old Jan 14, 2003
1BlackHatch's Avatar
1BlackHatch is an unknown quantity at this point
Ok I am having a problem with an install I just did and I need some help.
My system is:
Mb Quart 6.5 components (front)
Mb Quart 6x9s (rear)
Alpine Head Unit
Soundstream 5 channel amp
Anyways, what is happening is this. Whenever the headunit reaches a high volume setting the amp will cut out regardless of gain setting and honestly doesn't play very loud. I noticed this before and fixed it by changing the polarity on on of my speaker wires. It was fixed. Amp never cut out and screamed. Now the amp is cutting out again and not going very loud. BTW.. the amp stays nice and cool through all of this...
Any suggestions?
Thanks.
Old Jan 14, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
The facts:
1) it did the same thing before
2) wiring was the cause
The no brain answer is start double checking the wiring. Maybe have someone help you. They will catch what you are missing.
Soundstream makes good amps. Just like you said it should be screaming.
Old Jan 14, 2003
Just to run this by you, are there any grounding problems or polarity issues with the speaker output from the amp that could cause this?
Thanks in advance.
Old Jan 14, 2003
Regularjoe's Avatar
Bad Ground or Bad Power causing insufficient power to the amp.
- make sure the ground is as big as the power.
- make sure the ground is secure.
- make sure the metal was bare, NO paint etc.
As far as polarity on a speaker it makes no difference to the amp or to a speaker .... but you are using a crossover for the components. That may cause an issue if wired wrong. Not really sure on that one.
Overall though if all speakers match in polarity the bass will be stronger.
Old Jan 14, 2003
Yeah it could be the ground... I scraped it as best as i could, but it could be better... So is it bascially that as the volume gets louder, the amperage draw of the amp overpowers the ground if it is not done correctly? Which would explain why it works at low volume???
Thanks again
Old Jan 14, 2003
Regularjoe's Avatar
Current will be limited via the wires not only into the amp, but out.
Get sandpaper and scrape that metal really well. Shiney is the key here. Plus make sure the screw is very secure.
This will also help eliminate altenator whine in the system.
Old Jan 14, 2003
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
one of the + or - wires could have come off one of ur speakers.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
redcloud
25
Aug 12, 2015 01:23 PM
Dani1993
Jul 24, 2015 09:02 AM
Civic65
Jul 19, 2015 10:13 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
