Sub Question
Old Jan 5, 2003
civicSi's Avatar
civicSi is an unknown quantity at this point
Sub Question
Hey guys
Im running 2 10's pionners TS-W2541DVC i wanna know how i should run them
would i get more output from stereo or mono anyone know how i should set them up if i run them in mono?
Old Jan 5, 2003
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
Well there a couple of different ways to run them, but it depends on your amplifier. I assume that they are dual 4 ohm subs, which means you can run them at 4 ohm mono, 1 ohm mono, or 2 ohm stereo. Unless you have an higher end amp (like an xtant class d) then you won't be able to run at 1 ohm mono. Your best bet is 4 ohm mono tho.
Old Jan 5, 2003
civicSi's Avatar
don't think amps gonna stay stable at 1 ohm might start to shut off
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
