good 1000 watt amp
Old Dec 27, 2002
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
good 1000 watt amp
mo i need you again please...
ok, im looking for a cheaper, yet comparable in quality 1000 watt amp to run 2 10" W7's
Old Dec 27, 2002
mohawkboom's Avatar
What's the damn ohm load on those?..I can't find it on JL's site
Old Dec 27, 2002
dunno man, ill be goin to tweeter on sunday, i can ask if you want
Old Dec 27, 2002
Mystic3030's Avatar
Yup, i'm an A$$hole.
Quote
[hr]Originally posted by: mohawkboom
What's the damn ohm load on those?..I can't find it on JL's site[hr]
The 10 and 12 are single voice coil 3 ohm, and the 13 is a dual 4 ohm I beleive. I would suggest two JL 500/1's, or even better, if you have a little extra cash on hand, get a couple Phoenix Gold 600/2's or 800/1's......Dont skimp on the amps with W7's....they need a lot of juice....and go with 1" MDF....not 3/4...I was at my local car audio shop a couple months ago, and they built a box for one 12W7, and ran it off a JL 1000/1.....it cracked the box.....I've seen that happen a couple times with 3/4 MDF and the W7.
-Mystic
Old Dec 27, 2002
mohawkboom's Avatar
Okay..if they are SVC 3ohm..I'd say go with a JBL 1200.1 or an MTX 81000D.. The MTX is a little more expensive and has a slightly better built in crossover. Both put out around 1400Wrms into 1.5ohms..
Old Dec 28, 2002
LudlamTheory's Avatar
i boogie for the raindrops
isnt the jbl a bit low quality for w7's?
Old Dec 28, 2002
mohawkboom's Avatar
Nope...not at all..the crossover isn't the best but it's not terrible either..but as far as class D amps go..there is absolutely no difference in their "sq"....there is a difference between a Class D amp and a high quality Class A/B amp for subwoofer controll (damping) that can be easily noticed..but class A/B amps of that power are pretty damn expensive
Old Dec 28, 2002
DizWikedCivic's Avatar
if money is a factor then go with the jbl 1200.1 or the lanzar 1200, you can get those on ebay like 200-250
Old Dec 28, 2002
isnt 1400 watts a little much for the 10?
if not, where is a good place(besides the internet) to find MTX products, and is the MTX comparable to the JL 1000/1?
Old Dec 28, 2002
mohawkboom's Avatar
you said 2 10's/..700Wrms each isn't too much..the JL 1000/1 would be a better choice as it's a class a/b amp and has better damping properties than the best of class D amps can hope to have...but a 1000watt class a/b would draw alot of amperage at high power levels, and you need sometthing to either run 1.5ohm mono or 6ohms mono..or buy 2 seperate amps to run them 3ohm mono..
Old Dec 30, 2002
ok mo, so would you recommend spending the few extra bucks on the JL? or go with the benefits of the MTX?
Old Dec 30, 2002
Falcon's Avatar
Falcon is an unknown quantity at this point
Quote
you said 2 10's/..700Wrms each isn't too much..the JL 1000/1 would be a better choice as it's a class a/b amp and has better damping properties than the best of class D amps can hope to have...but a 1000watt class a/b would draw alot of amperage at high power levels, and you need sometthing to either run 1.5ohm mono or 6ohms mono..or buy 2 seperate amps to run them 3ohm mono..[hr]
Mohawk.. you're always mentioning "damping factors"... what are you reffering to?? are you talking about gain, or clipped signals or something like that??
EDIT:.. the second that i ask a question, i end up finding the answer for myself
for all who are interested,
Damping Factor: The ability of an amplifier to control the load without overhang. This applies to how tight the bass is. Usually the higher the number, the better, although it is debatable if anything over 50 is audible. Damping factor is calculated by dividing the load (speaker) impedance by the output impedance of the amplifier. Thus, a given amplifier’s damping factor will decrease as the speaker’s impedance decreases. This means an amp running at 4 ohms will provide tighter bass than at 2 ohms.
civic1316
May 29, 2015 05:13 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
JjAnGPeETuL
Nov 8, 2001 02:16 AM
