peXiglas?
Old Dec 18, 2002
LiLaSiiAn8's Avatar
peXiglas?
first of all, what is the difference between pexiglas and fiberglas? second, does anyone know how much each costs? in our tunks we have that card board and i was thinking of replacing it with pexiglas or fiberglas and i was wonder how much it was going to cost me. also, what type of tools should i plan on using with it? i heard that pexiglas is just like wood. thanks guys!
Old Dec 19, 2002
fonto's Avatar
The LA Clipper
I am not sure of an exact price, but it will probably cost Alot to fiberglass your whole trunk. If you have never done it before, you should definantly have a pro do it. There are a few peope from the LA area who can probably recommend good shops.
Old Dec 19, 2002
LiLaSiiAn8's Avatar
still whats the difference between fiberglass and pexiglas? and i don't want to do the whole trunk, i just want to replace the board with the exact same cut out. get it?
Old Dec 19, 2002
Ed's Avatar
Ed
plexiglass is just clear plastic sheeting
fiberglass is where you take fabric, resin and hardener to make a rigid light structure (not clear)
[L=http://www.thewarbird.com/installs/system2/subs.html[/L]
why not just buy a sheet of wood and cut it out?
Old Dec 19, 2002
LiLaSiiAn8's Avatar
cool thanx. i want it to be clear, yet sterdy. thanx ed!
Old Dec 19, 2002
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
I you want it to be clear and sturdy then you want either plexiglass or lexan. Lexan is a stronger version of plexiglass and has less flex at the same thickness, but it is more expensive.
Old Dec 19, 2002
LiLaSiiAn8's Avatar
ooh.. do you know where i can get some? either pexiglas or lexan? i heard you can get pexiglas at home depot, but i wanted to know if anyone else got it from there.
Old Dec 19, 2002
666's Avatar
666
666 is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-smile.gif[/IMG]Try selectproducts.com they have plexiglass, fiberglass and even carbon fiber.click here for select products
Old Dec 19, 2002
LiLaSiiAn8's Avatar
thanx dood!!
Old Dec 19, 2002
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
plexiglass is expensive.. why do you want to do that?
Old Dec 20, 2002
LudlamTheory's Avatar
i boogie for the raindrops
http://www.mcmaster.com/
they have plexiglas too... and be sure to get thick enough glass... and it scratches like nothing... plexi is a bitch to keep up
Old Dec 20, 2002
LiLaSiiAn8's Avatar
umm is there anything to keep it nice and clear?
Old Dec 20, 2002
well, one question, why would you want to show off your spare tire
Old Dec 20, 2002
LiLaSiiAn8's Avatar
bcuz i'mma gurl and i can do whatever i wanna do! [IMG]i/expressions/moon.gif[/IMG]
jk jk
i don't knoe, i just do! i want to slowly build a system and you have to start somewhere
Old Dec 20, 2002
this one would take me too long, i pass this one off to the next person
Old Dec 20, 2002
custom2k1's Avatar
Well heres an idea for a price. It cost me $162 for 1/2" 2'x4.5' piece, so to do the whole trunk floor its going to be quite expensive. Its normally about $15-$17 per square ft. My local lumbar yard sells both plexiglass and lexan.
