do I really need another amp?
Old Nov 28, 2002
dups's Avatar
dups is an unknown quantity at this point
Alright, I originally bought a 4-channel 35RMS/channel amp to drive my infinity components up front and the pioneer 3-ways in the back. The infinity's I decided were being underpowered so I bridged the infinity's and wired the pioneers up to the stock HU speaker input again instead of using the amp in the rear. I was talking to a friend and he said I really should get another amp if I want to run the 70watts to each infinity so I was thinking about getting an Alpine 2-channel 50RMS/channel amp to drive the rear speakers and I figured in the future I could play around with it if I wanted a sub. Is this a good idea? or should I be able to leave my system with the rear speakers going off the regular stock HU power and the components off the amp and still make it sound good? I think I'm just having trouble getting everything balanced for a good stage. Thanks!
Old Nov 28, 2002
LudlamTheory's Avatar
i boogie for the raindrops
sell that one and get a bigger 4 channel
Old Nov 28, 2002
dups's Avatar
The rear speakers I currently have are only supposed to take 40 watts per channel, the infinity's need 75 watts per channel. If I get a bigger four channel I'll be way over powering the rear speakers. I just wanna know if I even need to amp those rear speakers or if I should just leave it.
Old Nov 28, 2002
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
just stick wid the rears runnin off the HU power..... the rear is just filler anyway..... when i get components i'm gonna do the same thing... bridge em to run the fronts.... run the rear off HU.....
Old Nov 28, 2002
dups's Avatar
The only problem I seem to have run into by doing that is I cut out some bass. The fronts are overpowering the rear right now and so I'm thinking I either need to get a little more bass out of the rear or try adding a sub. Or maybe I should buy another amp and power a subwoofer off of it. What are the general opinions of the infinity basslinks? I know they aren't like JL subs, but are they decent? I don't want REALLY powerful subs so thats why I was wondering about those.
Old Nov 28, 2002
andyman97's Avatar
Turbo Guru
I'd get a good quality 4-channel amp, you can always adjust your output levels and if it is a decent amp, you can turn the rears down and the fronts up for optimal sound. If you still have stock rear speakers, I'd replace them with better quality, tho.
Old Nov 28, 2002
dups's Avatar
They aren't stock speakers in the rear. Pioneer 3-ways that handle 40watts RMS, the fronts take a lot more than that though. If I get a good quality amp I will destroy those rear speakers. I dunno, I'm considering an infinity basslink because they are real small and don't take up a lot of room, and then just take out the rear speakers maybe? Something to consider.
Old Nov 29, 2002
dragoon's Avatar
i'd sell the rears, put your stock rears back in, run them on deck power, and get a sub or two
Old Nov 29, 2002
Regularjoe's Avatar
Regularjoe is on a distinguished road
I would get an amp and subs next. Keep everything else as is.
Old Nov 30, 2002
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Even though your pioneer's are 40W RMS they still can handle the 75W that an amp would provide the 6 x 9's. I'm pretty sure that they probaly handle about 150W max.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
