Blue remote wire for sub amp... what to connect to?
Old Nov 27, 2002
MangoEX's Avatar
Just Be
MangoEX should not be trusted
The blue remote wire connects to the switched 12V wire (red wire on HU wiring harness) right? The one that plugs into the amp along with the 12v/grd. Thanks [IMG]i/expressions/beer_yum.gif[/IMG]
Old Nov 27, 2002
DizWikedCivic's Avatar
the remote wire goes to ur deck, mostly like it the bluw/white wire
Old Nov 27, 2002
dragoon's Avatar
ya if your deck came like mine with a "remote" thing tagged on one of the blue wires, it goes there.
Old Nov 27, 2002
civicvtec1ps's Avatar
Search and Learn
back of your deck. remote wire
Old Nov 27, 2002
fonto's Avatar
The LA Clipper
Don't connect it to the red wire!! I originally had "free" installation come with my headunit, and they hooked up the red wire. I wondered why my amp was always on, and why my amp wowould go into protection ALL of the time. At first I thought it was my amp...but then I re-did the wiring at the HU.
It is the light ble wire, and some harnesses will be labeled.
Old Nov 27, 2002
MangoEX's Avatar
Just Be
I hooked it up to the red wire labled "ACC".. there is no blue wire on the harness i bought. i figured since the red is a switched 12V wire, then it only goes on when the ignition is on
Old Dec 1, 2002
BlackIce's Avatar
BlackIce is an unknown quantity at this point
This may be getto but I hooked my 'remote wire" to the positive lead on the AC power outlet below the deck. That way, my amp turns on when I turn the ignition on and goes off when the key is out. I just wanted to hook it to something that would go on and off by using the key. It works for me, use at your own risk...
Old Dec 2, 2002
Ed's Avatar
Ed
The accessory wire on the ignition is often used as well. You shouldnt' have problems with that
Old Dec 2, 2002
fonto's Avatar
The LA Clipper
The problem with using the red wire is that your amps will stay on even when you shut your radio off, which kinda sucks
pincookie1
May 4, 2015 12:22 PM
MamaBear2015
May 3, 2015 02:17 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
AlphaInfinity
Dec 19, 2001 09:25 PM
clockwerx
Dec 13, 2001 12:39 PM
