sub recommendation
Old Oct 24, 2002
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
sub recommendation
sup dudes...... need some help...... what kinda sub do u guys recommend for rock music????...... i'm using an xplod rite now.... and its pretty bad....... i was thinking 12"....
Old Oct 24, 2002
LudlamTheory's Avatar
i boogie for the raindrops
ok... the standard questions...
1 - budget
2 - how loud do you wanna get
3 - only rock music? or do you occasionally listen to other stuff
4 - is there any brands that you DONT like
Old Oct 24, 2002
BlueTroll's Avatar
hum...
price: <250CAN which is about 150US.
i want it loud.... but i want it to be able to hear the bass like the different notes.... i don't want just thumping....
rock most of the time.... sometimes i'll listen to some hip hop......
subs i don't like??.... umm.... only the sony.. cuz thatz the only one i've tried.... my buddies JL is pretty sweet.... i'm pretty much open to suggestions.... i'll probably be runnin 200 watts RMS or so... haven't decided which amp i wanna buy yet....
i was lookin at cerwin-vegas... those any good??.... the IT series??
Old Oct 24, 2002
150 US total for 2, or 150 each, or are you looking for one sub.... also 200 rms can be a tad bit low...
Old Oct 24, 2002
BrotherSound's Avatar
BrotherSound is an unknown quantity at this point
I'm gonna get an "infinity Kappa perfect 10" at some point they're about $150usd here! they're awesome! and thier SPL rating is around 96db, thats really good. so you may not need such a powerful amp. I think a 10" might be a better choice for rock they're a little more tighter & responsive than 12"s. but not by a lot, they also carry a 12" kappa perfect.
Old Oct 24, 2002
BlueTroll's Avatar
about 150 for one sub.... i don't want to run that much power.... my speakers are 30 or 40RMS each.... so i don't want the bass to drown it out..... well.... i'm just saying 200watts for the sub.... but i'm not sure yet.... so how much power should my sub amp be around???.... 300rms ok?
hum... i guess i'm looking for a sub wid a good frequency range.
Old Oct 24, 2002
Quote
[hr]Originally posted by: BlueTroll
hum... i guess i'm looking for a sub wid a good frequency range.[hr]
thats the beauty of the kappa perfects. they have a high spl rating. the higher, the more efficient the driver which means less power required to run it, i would say anything from 100-150rms is perfect for it. it doubt it will drown you out too. just turn up or down the gain if so..
Old Oct 24, 2002
mohawkboom's Avatar
You might want to consider the Infinity Kappa subs..not the perfects..these have a green cone and play lower. Thy work quite good under low power applications. You might also want to consider a Kicker Comp VR 12...another good sub for low power
Old Oct 24, 2002
Les's Avatar
Les
Les is an unknown quantity at this point
could consider the elemental designs k series. 125 for the 12", 300 rms, elemental designs
Old Oct 25, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
idq ????
Old Oct 25, 2002
BlueTroll's Avatar
sooooo........... the best one for rock and a bit of hip hop is?????........ dam... i'm thinkin of gettin the 10' infinity kappa.... but should i go with a 10 or 12 inch, whatz the diff??
the infinity perfects r outta my price range.
but which kappa??
10" 4-ohm Component Subwoofer
or
10" 4-ohm Dual Voice Coil Component Sub
solarpunk70
Apr 12, 2016 11:43 AM
twd000
Oct 4, 2015 12:52 PM
MamaBear2015
Sep 27, 2015 06:31 PM
