replacing trunk floor with plywood???
Old Oct 12, 2002
Shadow's Avatar
Shadow is an unknown quantity at this point
i remember seeing a post where someone did this...
i need to know if there is a big diference if i use 1/2" or 3/4" plywood, also, he cut the floor across after where his box was and put hinges so he could get under the floor easily, anyone remember seeing this? or has anyone done this? i just dont want the box movin around and i dont want the floor to sag after time...
Old Oct 12, 2002
WhiteRabbit's Avatar
i replaced mine with MDF (man is it heavy!) i think mo used ply. much lighter, and even stiffer. I have bought 1/2 inch ply for a box I am building, and if press board is what most cars come with stock, then 1/2 will be more than enough for you. 3/4 will be stiffer and heavier, but its not like you are installing a working jackhammer on it, right? [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
in yoru position, id run 1/2
Old Oct 13, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
If it's not for an enclosure, 1/2" MDF with a cross brace underneath.
Old Oct 13, 2002
Shadow's Avatar
cool, so 1/2" ply it is!
thanks guys, now all i need are suggestions on what to do with the cargo net tie-downs that are attached to the metal trunk floor...
are the screwed in or snapped in?
Old Oct 13, 2002
CivicRiderCA's Avatar
CivicRiderCA is an unknown quantity at this point
They are screwed in....i know because i used one of them for my ground for my system [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Oct 13, 2002
MDF = Medium Density Fiberboard
IMO, plywood could buzz with the subs if it's the cheap variety. [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Oct 13, 2002
marine grade birch ply, or furniture grade. best to use for finishing work of any kind. also stiffer than MDF at a fraction of the weight.
Old Oct 14, 2002
Shadow's Avatar
any suggestions on unscrewing them? just use vice grips or something?
CarStuff
Dec 6, 2020 12:52 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
cperez53
Apr 16, 2015 09:31 PM
thesushiboy
Apr 12, 2015 02:54 AM
