running two amps?
Old Aug 7, 2002
MVHonda's Avatar
MVHonda is an unknown quantity at this point
running two amps?
I am running two amps off one line running back from the battery, I will split it in the trunk. The wire is 6 Gauge, I am wondering if there is a special way to run it or do I just split it and then run one to one way and one to the other? thanks for the help.
Old Aug 7, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Most people use a combination fuseholder/distristribution block. I suposse you could just get away with just a distribution block, but a little extra fuse protection dosn't hurt.
Old Aug 7, 2002
LuvDatCivic's Avatar
LuvDatCivic is an unknown quantity at this point
you should definitly use a combo. I once has a short that took place after my first fuse in my old car and it blew the two fuses in my block to pieces...if they werent therer i would have had to throw my amps in the garbage.
Old Aug 7, 2002
MVHonda's Avatar
thanks for your help, i appreciate the picture!, BTW, how can you make a link work on your profile?
also, is the gas tank directly under the back seat cushion? i was under the car yesterday and thats what it looks like.
Old Aug 7, 2002
Ben's Avatar
Ben
Ben is an unknown quantity at this point
what size amps are you running 6 gauge wire is not very big
Old Aug 9, 2002
MVHonda's Avatar
700 and 340 max.
Old Aug 9, 2002
Yukonart's Avatar
Yukonart will become famous soon enough
Best advice:
Replace wire from battery to distribution block with 4 gauge, then run 6 or 8 gauge from each terminal in the block to each amp. If you already have 6 gauge in there going to each amp, leave it, and just do the lead wire from the block to the battery. It'd cost something like $15-30 (ie: Monster, Lightning, etc) for 4 awg wire running from the block up to the battery (assuming you locate it somewhere in the trunk), and about $20-25 more for the block. Not sure how much more the combo blocks are, but that Fosgate one ICR has for a signature couldn't cost much more than that.
I was told by some pros that you want the fuse for the amps as close to the battery as possible. . give or take 6". (Somewhere in the engine compartment is usually best) This would obviously cost a little more for a separate fuse block, but you're running upwards of 500W RMS so spend a few more bucks and get a nice big one in there. A little more $$ now can save you a lot more $$$$ later. If you're really into preserving your equipment like I am, not only for the investment, but for the sound, you'll spend decent money on the supplemental equipment and wiring.
jackoncruzpr
May 24, 2015 12:24 AM
smmahan
Apr 15, 2015 08:17 PM
OPGForce
Feb 7, 2002 09:43 AM
NukeSilo
Jan 9, 2002 02:22 PM
mohawkboom
Nov 2, 2001 06:00 PM
