Choice of amps
Old Jul 29, 2002
BOYTOY's Avatar
BOYTOY is an unknown quantity at this point
Choice of amps
I have one kicker solo baric L7 10" sub woofer in my trunk........2 JL 6*9 in the rear deck............and two Alpine 6.5's in my doors.........if i want to run my whole system through an amp....do i need a 5 channel amp?? The kicker sub needs at least 600w cause that is what it plays RMS............What would be a good amp........not too pricey but not Cheap quality?? I also was looking through a Viper catalog and they have there amps rated 4 ohms .....2 ohms......and 1 ohm.....What are they talking about??
Old Jul 29, 2002
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
a 5 channel that can run all that at the proper RMS is gonna be either quite expensive or impossible to find, just get 2 amps. Personally I prefer Rockfords
Old Jul 29, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
You're gunna want two amps, a 4 channel and a mono block class D amp. The resistance, measured in ohms is 4 for the speakers, depending on whether your sub is a DVC it runs at 4 ohms or 2 ohms. The lower the resistance the more power that goes to the speaker. You have to be careful to make sure that your amp can run at the lower resistance without overheating. For a 4 channel i would recommend the MTX 6304, and for a mono i would recommend the MTX 6500 D. The 6304 is $294 shipped at onlinecarstereo, and the 6500D is $306 shipped. Both are underated and expect the 6500D to feed your sub at least 700 watts. Both are pretty solid and of good quality. You will also need a 4 guage wiring kit with the amps and a distrubition block. Good Luck.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
