stereo how to..?
Old Jul 23, 2002
soopason's Avatar
soopason is an unknown quantity at this point
stereo how to..?
n e one eva seen a system hooked up to a STOCK DECK? ive seen it b4...but dont kno how to hook it up ...if ya kno how to..could ya give me a lil how to? id really appreciate it..thankz
Old Jul 23, 2002
smpcivic's Avatar
smpcivic is an unknown quantity at this point
You could do it fairly easy...it will not sound as good as getting a new HU though.....all you need to do is connect the rear speaker wires in your car to the amp....you may need a cross-over box if the amp only supports RCA plugs.
Old Jul 23, 2002
soopason's Avatar
yessss thanx man ill try it out and see how it sounds...but if it dont sound good..could i just hook up an EQ?
Old Jul 23, 2002
ricewashed's Avatar
ricewashed is an unknown quantity at this point
You should just hook up some subs. It will be better that way. You need RCA cables and you might want a filter that takes away all the high frequencies.
As for the rest... I'm tired and do not feel like lookingup the info. But using the rear as the signal sounds great to me. Filter out the highs to the rear speakers.
Or you can just save up about 200 bucks(350 would be nice) and get something off ebay. I got my $900 Sony deck off ebay for $390 shipped.
Old Jul 23, 2002
JJF's Avatar
JJF
JJF is an unknown quantity at this point
The part you need is called a line output converter (LOC) it transfers high level signal to low level signal, like what your amp needs. Make sure you get a good one, install edge make a decent one for about $25. You also can add a line driver output to increase the voltage in your rca's. Any questions how to just ask.
SammySC
121
Apr 7, 2017 07:43 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
zeshan7616
Sep 15, 2015 12:24 PM
lolhowell
Photography & Videography
Sep 11, 2015 05:09 PM
J-Fly
Sep 10, 2015 08:39 PM
