final advice on speakers n amp
Old Jul 13, 2002
jerseysurfer23's Avatar
jerseysurfer23 is an unknown quantity at this point
yeah i got a pioneer 9200 headunit. i think im bout to go buy some new 6 1/2's n 6x9's for my car. i was lookin at the PIONEER GM-X962 AMP 2CH 760WATTS Amp. Would you suggest i wire both sets of speakers up to the amp or what? Or shuold i go for a 4 channel amp instead? I've seen people talk about componet speakers... should i go with them in the front?? would i need to hook them up to an amp or what. yeah im not really sure about it but ne guidance would be appreicated.
Old Jul 13, 2002
mohawkboom's Avatar
Wow you need to do alot more learnin before you spend alot more cash !!!..
Please visit both
sounddomain.com
and
termpro.com and read through the forums and such.. also carsound.com's forums.. very informative and should give you more ideas and such..
Cheers
Mohawk
Old Jul 14, 2002
local0nigga's Avatar
local0nigga is an unknown quantity at this point
whats up g
here im a tell ya sum basics and shyt
1. it you want a high quality system avoid rear speakers, this is because the sound from these speakers are reaching your ears at a diffent time than the front speakers are. This makes problems in frequencies and also may cause cancellation. What you want to do is make a front sound stage
2. to make a front sound stage you can hook up 6.5 coaxials or component speakers in the front (component speakers will give you a much better high quality sound) i would not recommend using a 760 watt amp that would be over kill for the speaker. you would want something around 100 watts x 2
ps if you want to hook up all four speakers u need a 4 channel amp, (i don't recommend hooking up four speakers though)
stay real homie
redcloud
25
Aug 12, 2015 01:23 PM
Nalmonte
Jul 22, 2015 09:08 AM
