Matching Amp to Cerwin-Vega HED10 Sub?
Old Jul 11, 2002
klam's Avatar
klam is an unknown quantity at this point
After reading favorable reviews on Mohawk's recommendation for the Cerwin-Vega HED series of subs, I'm contemplating a single 10" just to add some richness to my music (not for head thumping). I also decided against the Infinity Basslink just because everybody seems to be telling me that you can get better by assembling it yourself. I figure 10" would be good enough, as size and cost are major considerations for me. I can get this for $99 CAD.
So anyway, I need to match an amp to this sub, who's specs are:
Cerwin-Vega HED-10SVC
4 ohms
power range 35-150 watts RMS
peak power 300 watts
sensitivity 88 dB
Any recommendations? Probably just want to stick to a 2/1 or mono amp just to drive the sub.
Old Jul 11, 2002
klam's Avatar
Edit: The one I can get is dual-voice coil 4ohm/coil version.
Old Jul 11, 2002
klam's Avatar
How are MTX 6xxx series subs? They're pretty reasonably priced too.
Old Jul 12, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
Stay away from MTX subs, unreliable and does not have great sq.
Old Jul 12, 2002
klam's Avatar
Ok, so maybe I'll just stick with the Cerwin-Vega HEDs. How are MTX amps?
Old Jul 12, 2002
pinoyVTi's Avatar
pinoyVTi is an unknown quantity at this point
MTX amps are ok...
the old MTX black gold subs had good sq
whats your budget on the amp?
If its dvc, with each DVC at 4ohms...
You can get one amp but youd have to wire the voicecoils in series to have an 8ohm load since not all amps can do 2ohm bridged mono...you can get another sub and have 2ohms stereo load or a 4 ohm mono load...
4 Ohm DVCs are pretty hard to incorporate into a design if you just want one sub.
Old Jul 12, 2002
klam's Avatar
In that case, I'll need to stick with the single voice coil version.
My budget is at most $150 USD.
Old Jul 12, 2002
pinoyVTi's Avatar
Are you currently using an amp on your mids & highs?
Here are some suggestions for an amp:
If you dont have an amp for your mids & highs:
USX4065 4 X 65 : use channels 1 & 2 for your front speakers. 3 & 4 bridged for your sub...run your rears off of the HU. $125 at thezeb.com
usacoustics is a cheap but very reliable & clean amp brand. They have the sub for $69.99
If you are going to use a DVC sub or SVC,
Soundstream Angina - 200x1 @ 2 ohm (watts RMS) at thezeb.com
Old Jul 12, 2002
Ed's Avatar
Ed
Quote
[hr]Originally posted by: pinoyVTi
Soundstream Angina - 200x1 @ 2 ohm (watts RMS) at thezeb.com[hr]
That's what I do [IMG]i/expressions/face-icon-small-smile.gif[/IMG] I have a single sub and a 4 channel amp, with two bridged for the sub then the other two for the front, and the rear (which is mostly faded out) is powered by the HU. I think it's a good cheap setup, especuially since you don't really need rear speakers for much [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
-Ed
also, i've been looking to buy that sub also, this is the cheapest i've foudn it: http://www.dynadirect.com/electronic...rwin-vega.html
Old Jul 12, 2002
pinoyVTi's Avatar
yup..thats the simplest set-up you can have...less hassle on the install...good sound.
Just dont expect to win any SPL battles[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
IMO, A balanced system is better than an all bass system...
Old Jul 12, 2002
klam's Avatar
Quote
No I don't have an amp for my full-range speakers.
I was wondering, if I do go for a mono/2-channel amp just to power the sub. Will the sub overpower my regular speakers? The RMS (4ohm) is 150W on the sub, so if I go for a amp that puts out a RMS of 150W, would that be an ok setup?
If I do go for the 4-channel to also power the front door speakers, how do those wire up to the amp? I assume that there are connections from the headunit to amp (in trunk) and then connections from the amp (in trunk) back out to the front door speakers?
Old Jul 12, 2002
klam's Avatar
Quote
[hr]also, i've been looking to buy that sub also, this is the cheapest i've foudn it: http://www.dynadirect.com/electronics-car-audio-subwoofers-cerwin-vega.html [hr]
Ed, I thought you already had an 8" JL sub in that neat little spare tire location? I guess you're looking for a change? [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 12, 2002
Ed's Avatar
Ed
hehe, yeah, i'm always looking [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 13, 2002
klam's Avatar
Ed, how was the sound out of your 8" sub and sub location? How did you make your enclosure?
Old Jul 13, 2002
Ed's Avatar
Ed
It's sitting in the under teh stock rear floor right next to the spare tire. I just went out and measured the space i had and made the biggest box i could, it came out just like .05 ft^3 below the recommended. It's an MDF box, i'm thinking about trying to glass it and/or maybe make a ported box. I haven't really had too much especience with any other sub,so i can't really answer that.. but I think it's good, for it's size and about 150 watts rms.
-Ed
Old Jul 16, 2002
klam's Avatar
Ed, I can't seem to find pictures of your sub box set up? I remember seeing them before, but I can't find them? Would you still have them?
Old Jul 16, 2002
Ed's Avatar
Ed
Well, my computer had a virus recently, it killed a lot of my jpgs, buit i'll try take some and put them up. I should have it later today [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
-Ed
Old Jul 19, 2002
Ed's Avatar
Ed
sorry, it's takign me a while, hopefully i can get them tomorrow, if nothign comes up.
while i'm posting, i have a question about some Cerwin Vega HEDs:
THey say that they are recommended for a sealed box, will they sound any better in a vented enclosure? I tried looking for the specifications to type into winisd, but i can't seem to find the specifications of that sub. thanks for any help,
-Ed
GolNat
Nov 27, 2018 03:32 PM
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Bonobo
Oct 2, 2015 06:58 PM
Mc7602
Sep 17, 2015 02:01 PM
