Ok 3d needs some help please!
Old Jul 8, 2002
3dStylz's Avatar
3dStylz is an unknown quantity at this point
OK right now I have a Kenwood X811 head unit that is running infinity reference 6.5" up front Infinity Kappa's in the rear deck and two 300 watt amps that are powering two tens....
Now the problem
I am redoing my set up while making a custome sub box. I am switching too two 12's that I am gonna run with a new 600 watt amp and then run the front and back speakers with the other two amps. Now I have the two amps split off of one RCA wire with some spliters. I have the problem though that my deck says I have front channel RCA's and a Non-Fading RCA so how am I supposed to connect my kappa's to and amp and have a signal going to them? Also if I am running 1200 watts will I need a H/O alt or a cap?
Thanks for any help.
Old Jul 8, 2002
white97ex's Avatar
white97ex is an unknown quantity at this point
im not familiar with the amps, but dont they have a set of pre-amp outputs for in and out? if they do just go from your deck to the amp, then from amp to other amp and so on...if that doesn't work you can always just use a splitter.
Old Jul 8, 2002
3dStylz's Avatar
correct me if I am wrong but using a splitter on the rca's on the deck splits the left and right signal I am trying to find a signal for my rear speakers... would a non fading work for those?
Old Jul 10, 2002
mohawkboom's Avatar
the non-fading pre-out s generally the subwoofer out. How many sets of RCA's are coming out the back of your HU?. if it's 2. Run a splitter to the amps. you won't be able to fade from front to rear, but you can use the amps gains for that.
Cheers
Mohawk
