will amp blow speakers
Old Jul 1, 2002
CelCUs's Avatar
CelCUs is an unknown quantity at this point
I replaced the stock speakers in my sedan with kicker k60 6.5's and got a RF 600.4 punch amp for really cheap and want to know if it's too powerful for the speakers. The speakers are 65 watts RMS and 125? Max I think. . . the RF amp is 75watts X 4 into 4 ohms and 150watts into 2 ohms. I was initially going to get a 400.4 but I didn't really want to pass up the deal i got on this amp. Should I sell it and get another amp or put it on??
Old Jul 2, 2002
Slickwillie's Avatar
Slickwillie is an unknown quantity at this point
you should be ok. Usually it is alright to go allitle over the rms.
Aaron
Old Jul 3, 2002
RockfordFosgateBwoy's Avatar
RockfordFosgateBwoy is an unknown quantity at this point
you'll be fine...no problems...
music is dynamic
RF Bwoy
Old Jul 3, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
Too little power and distortion will damage speakers before too much power will. If they are crossed over right, then you could run 500watts to each speaker without damage. Correct me if I'm wrong Mohawkboom.....but you cant cause I'm right!!!
Old Jul 3, 2002
civic510's Avatar
civic510 is an unknown quantity at this point
no amp will cause speaker damage, underpowered or overpowered. if it's underpowered, you run the risk of running the amp into clipping because you can't turn up the volume that much. if it's overpowered then you just gotta be careful how much you turn up the volume. just run the gains down on the amp a little. mohawk, correct me if I'm wrong.
Old Jul 3, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
too little power will cause the amp to clip, and there is a reason you will blow a speaker
too much power might go beyond the thermal limits of the speaker, you can give a speaker 10000 watts if it doesnt go beyond the thermal limits of the speaker! but 10k will mostlikly go beyond the limits
UltraHDGames
Jun 8, 2016 05:16 PM
raymondxcho
Sep 29, 2015 09:00 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
