Old Jul 1, 2002
noahnoah's Avatar
noahnoah is an unknown quantity at this point
What is the difference between a 16-volt (20 volt surge) and 24 volt power capacitor such as a lightning cap or what not. I know what a volt is, but how is this going to effect my system. If anyone knows the specifics of what these voltage ratings indicate I would really appreciate an explanation.
Old Jul 1, 2002
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
All it is letting you know is how much voltage capacity it can handle in it, like a 16 volt cap can hold 16 volts over the + and - terminals. If you want to really check what your rating is just pull out the ol' trusty voltmeter and lay it across the terminals and check the voltage.
Joe
Old Jul 1, 2002
noahnoah's Avatar
I was looking at two different brands, one was 16 volt and the other was 24 volts. Which one based on those characteristics would be a better cap?
Old Jul 2, 2002
WhiteRabbit's Avatar
they would perform the same
thats only their voltage limit
your alt puts out 14v, so itll never see the difference.
