how the hell do you install these things!?!(6.5" alpine "type R's)
i recently bought alpine type r 6.5 speakers for my front door now i have no clue how to install it....for those who have this speaker....how did you install it??
edit:well i tried to install it but the speaker sticks too far out....and there is a big gap between the front of the speaker and the door....im giving up and probably gonna get them in 5 1/4 unless someone knows a solution
I hacked apart the factory speaker with a dremel tool, using the basket as a "spacer". Works perfectly.
Or, build a spacer out of MDF OR get a spacer from a car audio shop. They're cheap.
Quote
[hr]Originally posted by: ELaudio
Or, build a spacer out of MDF OR get a spacer from a car audio shop. They're cheap.[hr]
DIY King
I'de buy a universal speaker spacer and mount that by drilling holes in the sheet metal and using some screws. Check it: Injection Molded Speaker Adapters I bought the SS65 Universal 5-1/4" or 6-1/2" Speaker Spacer.
DIY King
Just something that I found at a hardware store. I think it was Home Depot. They have to be long enough to go past the spacer and bite into the metal. Although I want to redo this. Instead I want to install these threaded studs that you can screw bolts into. I think that will be cleaner. Also, I used little washers so that I could spread the force evenly across the speaker walls and not do any damage. I'de look for those little studs with threaded holes and bolts with large heads though. That would be a very clean install.
DIY King
You used the speaker spacer that I reccomended? If the speaker sticks out too far how is it possible that there is a gap betwean the front of the speaker and the door? Can you please elaborate...
Schneiderman
May 24, 2015 01:14 PM
One_PeeJay
May 17, 2015 05:31 PM
cloudguy
Apr 28, 2015 05:02 AM
