fire wall probs
Old Jun 2, 2002
Handog's Avatar
Handog is an unknown quantity at this point
fire wall probs
i cant seem to get through the fire wall. a little help please.
Old Jun 2, 2002
Ed's Avatar
Ed
It took me a good few hours to get my power through. As long as you can locate the grommet, it's un the passenger side footwell behind the plastic lining, you should be able to cut a chunk of it out and poke it through. I found it slighyly easier to cut the grommet from the underside of the car, not by much though. I used 4 gauge and had to cut it with a hobby knife a lot [IMG]i/expressions/face-icon-small-tongue.gif[/IMG] Good Luck!
-Ed
Old Jun 3, 2002
civicpimpin01's Avatar
civicpimpin01 is an unknown quantity at this point
That sounds good Ed.
Old Jun 4, 2002
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
there should be a plug where your wires go through in the passenger side firewall, you should be able to push the rubber plug to the side and run your wire through the gap left from moving the rubber. i used zero guage, and had no problem.
Old Jun 5, 2002
CivicRiderCA's Avatar
CivicRiderCA is an unknown quantity at this point
I did it the old fashion way: I unbent a wire coathanger and shoved it through the grommet, then taped the end of my wire to one of the ends of the coat hanger and pulled it through the rest of the way...worked like a charm
Old Jun 5, 2002
microdot's Avatar
microdot is an unknown quantity at this point
I have an 02 and the rubber plug was inbetween the passenger and driver seats on the firewall. I just took a knife and cut a small hole, then pushed the wire through.
Old Jun 6, 2002
VNlilMAN's Avatar
The Standard One
ya i didn't even want to try getting through there cause it seemed almost impossible so i just ran it through the fender
tropicola
Sep 25, 2015 07:02 PM
Skunkone
Sep 24, 2015 04:38 PM
NROD315
Sep 4, 2015 09:22 PM
napkins
Aug 12, 2015 04:20 PM
