2002 ex cluster lights dead
Old Oct 14, 2017
310civicEX's Avatar
310civicEX is an unknown quantity at this point
is there something going on here? the far 3 are dead...tach/temp PLUS the odometer...all dead and when i put new bulbs in, still dead.. anybody got intel on that?....
ALSO...when i rev engine speedo moves with tach...thats wack
Old Oct 14, 2017
Re: 2002 ex cluster lights dead
Ummmm.......since the gauges run off of data straight out of the PCM....I'd want to check the PCM data list to make sure the vehicle speed data stays at zero when you rev it up....
Then do a gauge cluster self test and see if all gauges sweep properly and warning lights blink
Old Oct 15, 2017
310civicEX's Avatar
top row has only one hot wire with ignition on and lights on....... the BLACK/RED wire..
bottom row has WHITE/RED AND YELLOW/RED the rest nothing.
Old Oct 15, 2017
310civicEX's Avatar
IF THIS IS CORRECT then im even more confused because everything works ...but the lights for half the tach, fuel and odometer backlight.
Old Oct 15, 2017
310civicEX's Avatar
is this correct? should i try it?
