Subwoofer Acting Up
Old Jul 21, 2012
Hondanog's Avatar
Hondanog is an unknown quantity at this point
Subwoofer Acting Up
I have a 2005 Honda Civic coupe LX SE, and I recently installed a Dual amplifier and subwoofer. Because the stock stereo (to my knowledge) doesn't have a RCA input, I used a hi-low converter. It has two wires for the right speaker, two for the left, and two to ground it. I hooked the two ground wires directly into the ground in the amp. Every time I turn on the car, the sub plays a low bass sound for a few seconds, as if the amp is turning on. The same thing happens when I turn the car off. Does anybody know how to fix this?
Old Jul 21, 2012
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: Subwoofer Acting Up
Probably the only way to fix it would be a relay for the amp. The cheaper amps will do that or pop when they are turned on or off.
How do you have the amp wired for power?
Old Jul 22, 2012
rjones7755's Avatar
I had the same thing happen to me when i first got my subs, as it turns out it was a faulty bass boost remote for the amp, just one more think to look into if you have one.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
wingsfan19
Oct 1, 2015 03:45 AM
Skunkone
Sep 24, 2015 04:38 PM
BBrosario
Sep 17, 2015 07:51 PM
wingsfan19
15
Sep 2, 2015 02:15 AM
