Running subs on road trip
Old Jun 10, 2012
coupedeill's Avatar
not new to this
coupedeill is an unknown quantity at this point
Im going on another U.S/Canada road trip (appx 1100 miles each way) I normally give the car 20min or so whenever I stop for fuel but is that enough break for the amp. I wont have the gain up on the amp and it wont be on blast the whole time but still the amp will be powered and getting pretty hot. Like anything else the more you use it... so I wonder if I should pull the inline fuse periodically or something along the way? Dont want to kill it, I'm not running anything crazy just a single 12 on a 350 max.
Old Jun 10, 2012
GolNat's Avatar
Prelude Owner
Re: Running subs on road trip
If its a good quality amp and it isn't stuffed somewhere where it can't breath then it will be fine. As long as you don't have anything right up against the amp it will be able to cool it self.
Old Jun 10, 2012
You should be fine. I've done numerous 1300+ mile road trips blasting my music.. lol
Old Jun 10, 2012
lowlife9's Avatar
amps are designed to get hot if it hasn't died yet i doubt it will on your trip.
Old Jun 10, 2012
Kennykid2002's Avatar
Kenny the Ricer
This
Even if you have a bad quality amp, most often than not, they will have a self protection feature where if the amps become too hot, they will shut themselves off. If your amp is shutting off during the trip, its probably time to turn off the music for a bit.
I run a JL 500/1v2, which shuts off at high temps, or if voltage drops below 10V.
I drove 480 miles on one trip with one bathroom break, and I haven't had it shut off on me, though I also am not running it full blast all the way there.
Old Jun 11, 2012
coupedeill's Avatar
not new to this
Thanks fella's, I got a pretty decent set up but my amp is older - bazooka el series. Looked around but couldnt find if it had thermal protection...regardless I wont sweat it.
paddystrang
May 18, 2015 09:56 PM
tylerswire
May 6, 2015 12:16 PM
bsmiley
Apr 27, 2015 01:27 PM
dragonsblood
Apr 27, 2015 12:28 PM
TheRubixHorse
Apr 17, 2015 08:55 AM
