After market speakers in an 01 sedan...
Old May 3, 2011
Harris214's Avatar
Harris214 is a jewel in the roughHarris214 is a jewel in the roughHarris214 is a jewel in the rough
Sorry if this has been stickied but, I just put in a pair of infinity speakers in the front doors of my civic. What did you guys do about protecting the back of your speakers from rain water that gets down in to the door? What kind of material did you use? I've tried plastic wrapping but obviously it vibrates the plastic and you can here it... any suggestions?
Old May 3, 2011
lowlife9's Avatar
Re: After market speakers in an 01 sedan...
you can get foam speaker baffles and then just cut the bottom half out to let the air pressure out or it wont sound good.
http://www.sonicelectronix.com/cat_i...r-baffles.html
Old May 3, 2011
ive had infinity for 8 yrs in there and never had them fail from water being all over them. and believe me there was water back there all the time rain or car wash. they can take it so long as your connections are good. thats the only weak point is corroded connections. its best if you can solder the wire directly to the speaker terminals and then seal them with a waterproof non-conducting adhesive like plumbers goop.
Old May 4, 2011
Harris214's Avatar
Ok i planned on just leaving them exposed, I just dont wanna ruin a pair of $100 speakers, you know. So the speakers themselves can take the water and be just fine?
Old May 4, 2011
Shift-E's Avatar
That Dude with the Questions
Im guessing the winters arent bad where you are Gear box. I would be scarred of having them get wet then freeze :S
Old May 4, 2011
i used to live in IL for 5 yrs and it rained hard every other day (or snowed/freezing rain in the winter with -15F temps). speakers always sounded great even covered with water.
Old May 4, 2011
Harris214's Avatar
You dont have marine speakers though right?
Old May 4, 2011
just regular infinity reference 6.5 inch speakers from 2002.
Old May 5, 2011
Shift-E's Avatar
That's good to know, gives me a little peace of mind knowing that if I go aftermarket I have nothing to worry bout
Old May 5, 2011
Harris214's Avatar
Alright ill just do that. I thought about wrapping the exposed part of the speaker with a few layers like plastic food wrap. Good idea or not so much?
Old May 5, 2011
thing is, that will prolly cause more problem trapping the water in and possibly getting stuck in the speaker. not to mention affecting the sound quality. aftermarket speakers are totally water resistant, all the materials are made so that water is not an issue. now stock paper cone speakers, forget it. they will warp and tear and fail after a while. ive seen plenty of stock speakers that got wet and it wasnt pretty. but aftermarket is made with rubber, butyl, and plastics. nothing that water will affect and there are no electronics that matter other than the speaker terminals.
Old May 6, 2011
electric130's Avatar
i'm with gearbox on this. i've never had a problem with the speakers freezing or getting wet. you're putting them in the same spot the crappy OEM ones were, so they'll be fine.
Old May 6, 2011
Kennykid2002's Avatar
Kenny the Ricer
I have marine grade speakers in mine, so doesn't matter :P
But yes on the connection part,
What I suggest, is solder the connection, then either heat shrink tubing, or hot glue to cover it up
Old May 6, 2011
yeah you could always buy marine speakers...
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
Cam Diaz
Sep 28, 2015 08:34 PM
Gsxtacy
Sep 12, 2015 01:09 AM
