Install help needed
Old Apr 20, 2002
AlexLx's Avatar
AlexLx is an unknown quantity at this point
Install help needed
I got the door panel off but how do i take out the stock speaker from inside the stock plastic mount? Will i NEED to use this with my other speakers since it is a fit for the pre-molded holes in the door? Or could i just buy the scoshe speaker spacers and use them in place of the stock speaker mount? I NEED HELP! Ready to order my kappa 60.3...
Old Apr 20, 2002
CivicRiderCA's Avatar
CivicRiderCA is an unknown quantity at this point
you need to buy or make some spacers. My infinity kappy 5.25 compontents needed an inch of space added. MDF is best, or plywood i've been told.
I just installed mine yesterday, took 10 hours to install including a new amp and all the wires. Good luck.
Old Apr 21, 2002
mohawkboom's Avatar
the stock speaker stays in it's plastic housing.. it's glued to it and the VOice coild is as well..you cannot use it as a spacer. buy the Scoche Speaker spacer..or make one..
Cheers
Mohawk
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
bsmiley
Apr 27, 2015 01:27 PM
Myredjonda
Apr 14, 2015 07:00 PM
STYLIN2K2
Mid West
Nov 8, 2001 02:18 PM
