to amp, or not to amp???
Old Jan 4, 2010
Pongo08's Avatar
Pongo08 is an unknown quantity at this point
ok so im not going to put in a sub. i just want to replace the stock speakers with really nice ones. im not completely against having an amp, i just would rather not get one if theres not going to be much of a difference. which of the two (good speakers meant to be un-amped vs. those meant to be amped) will sounds better and will it be that much of a difference???? also what brands are recommended? ive been told the top dogs are pretty much pioneer and infinity. im not too worried about price..... as long as its not ridiculous.
Old Jan 4, 2010
amatias's Avatar
amatias is an unknown quantity at this point
Re: to amp, or not to amp???
you'll notice a difference, most external amps make more rms power than head units. and aftermarket speakers can also handle a lot more wattage too.
Old Jan 4, 2010
lowlife9's Avatar
those definitely are not the top dogs MB QUART,FOCAL, diamond audio,morel, just to name a few and you always use a amp or amps when using after market speakers.i personally use mb quart components front and back with alpine v power amps which sound amazing and wont break the bank dont forget good quality wires dont go shoping at walmart for a kit use rockford,monster,tsunami thats what i use.
Old Jan 4, 2010
Pongo08's Avatar
alright guys thanks alot!! anything else i should know? about the whole set up in general. btw should i stay away from Best Buy???? i have a Car Toys where i am and i hear theyre better.
Old Jan 4, 2010
if you listen to music fairly loud, get the amp. if just normal to low, stick with speakers only. but decide first cause if you dont want the amp, you should get lower power handling speakers like some pioneers that are around 35w rms so that you are not underpowering them. but if you get an amp, then you will need higher power handling speakers like 60wrms+ and the amp should provide 3/4 of their max rated rms power. infinity and pioneer are good lower end speaker if you dont have alot of $$ but still want good sound.
Old Jan 4, 2010
lowlife9's Avatar
best buy has a very limited selection of brands i would go to your local audio store and look for last years model amps and speakers they should be substantially cheaper with a wider array of brands to choose from or you could buy online this is a good cheap and reputable site
http://www.sonicelectronix.com/
Old Jan 4, 2010
also carmedia1.com has pretty good prices but they raised alot of their dynamat stuff.
Old Jan 5, 2010
Pongo08's Avatar
thanks alot guys!! this really helps!!
Old Jan 6, 2010
SPUNKYcivy01's Avatar
SPUNKYcivy01 is an unknown quantity at this point
If you dont have an amp, aftermarket speakers distort like crazy when turned up.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
