aktermarket stereo interferance!
Old Dec 20, 2009
racwade2003's Avatar
racwade2003 is an unknown quantity at this point
I just bought a pioneer double din for my 07 civic si,I installed it and there is a fuzz sound in all my speakers,i took the radio and put it in my 2000 accord and it worked fine and sounded good.any ideas of why my civic has a interferance problem?cause i wired it up the same way in the accord and it worked fine so i know its not the stereo???
Old Dec 20, 2009
Re: aktermarket stereo interferance!
did you connect the regular antenna and the "power" antenna wire? even tho there is no real power antenna, newer civics have an antenna booster unit that needs to be powered, otherwise reception will be bad. if cd also makes fuzz sounds, you prolly have a bad ground. try to ground the pioneer deck directly to the car body (bare metal) and do not use the oem honda harness ground wire. if that doesnt work, not sure what else you can try.
Old Dec 22, 2009
04 Honda Civic's Avatar
I used the OEM black wire to wire my radio and have no problems, but I also have a 2004 not a 2007. I honestly though that the OEM ground is the best ground to use simply because no OEM radios have static from factory so why should an aftermarket have static with the OEM ground.
What ground wire did you use?
Old Dec 22, 2009
EMDos's Avatar
EMDos is an unknown quantity at this point
Sometimes the rca piko fuses blowout on pioneer decks causing horrible static. Its an easy fix.
Old Dec 22, 2009
yeah ive heard that pioneers have issues with the rcas. someone here actually wrapped ground wire around them and stopped the static.
and the reason why aftermarket decks have more problem is they are higher power than oem and require bigger power/ground cables to function correctly. most aftermarket units are 2x more powerful than stock (10w per channel vs 20w).
SammySC
121
Apr 7, 2017 07:43 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
zeshan7616
Sep 15, 2015 12:24 PM
lolhowell
Photography & Videography
Sep 11, 2015 05:09 PM
J-Fly
Sep 10, 2015 08:39 PM
