Drivers side A-pillar wires
Old Aug 31, 2009
curt540's Avatar
curt540 is an unknown quantity at this point
Does anyone know what are the wires that run up the drivers side a-pillar.....i noticed a small wire sticking out the side of the pillar cover so i took it off and found two wires running up it and one of them has been cut.
Old Aug 31, 2009
Re: Drivers side A-pillar wires
dome light, moonroof motor, and some other stuff
Old Sep 5, 2009
curt540's Avatar
i wish i new what wire was cut then because everything seems to work. do you know where the antenna is run? my fm and am have never worked properly and honda has just told me that its my head unit. i didnt agree with them but when i bought my new head unit i asked the tech to check out the antenna and he said it was all good on the unit. is there another point where the cable could either been cut or come loose? Ive got an 04' coupe if that helps.
Old Sep 5, 2009
Foffie's Avatar
Im a Senior Member. Take that Noobs!!
Foffie has a spectacular aura aboutFoffie has a spectacular aura about
somebody prolly put guages on the a pillar and then took em out and just cut the wire and didn't actually remove it
Old Sep 5, 2009
for bad reception, its usually the "power antenna" wire that the installer forgets to hook up. even tho we have glass mount antenna, you still must hook that wire up otherwise reception will be terrible. just plugging in that big antenna adapter in the rear of the deck is not good enough. i have alpine deck and fm sounds like cd quality.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ashlava71
May 16, 2015 12:54 PM
ej8
Apr 13, 2015 06:36 PM
johnnieblazze
Dec 6, 2001 03:07 PM
mwwhonda
Nov 7, 2001 07:24 PM
