Radio Code, HELP
Old Nov 14, 2008
JrCivicEX02Coup's Avatar
JrCivicEX02Coup is an unknown quantity at this point
Question Radio Code, HELP
I had a heat blog put in my car before winter starts here in Alberta, Canada. I didn't notice anything until I arrived home and saw the writting on the stereo asking for a code. The shop is closed and they are open monday to friday. Then I started searching this site and found out I could fix it myself, I held 1 & 6 and turned on the radio and got codes 2414 and 7953. Then after that I got ERRE. What am I suppost to do? Any help would be greatly appriciated
Old Nov 15, 2008
manahoonie's Avatar
Re: Radio Code, HELP
check the paperwork you got with your car... somewhere in there should be a card of some sort that has the radio code on it.
otherwise, you have to go to the dealership, and they can look up your radio code or something like that
Old Nov 15, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
ok your in the right direction. When your hold 1 & 6, the numbers you get are your cd players serial number. That is a little trick to get the numbers. On older honda's you must remove the radio, the serial is on the back of the radio. Honda radio's have an anti-theft device with a 5 digit code. If you do not have it you can call the dealership with that serial you just got and they should be able to give you a radio code. You cannot get this code with a VIN the codes are radio specific. I no longer work at honda so I cannot get it for you anymore.
The car comes with an Anti'Theft Radio Code card about the size of a business card. If you don't have this, one place to look for the number is on the inside edges of the glovebox. On PDI at the dealership you are 'suppose' to put a small white sticker w/ the code & serial on the inside edge. It's about the size of your pinkie finger. The code will be 5 digits with the serial under it.
The ERROR messages you are getting are a result of too many incorrect codes being entered...so you messed the with the buttons. The radio will lock itself up at this point. To reset, disconnect the neg- terminal on the battery for about 30 seconds. The error should reset and you will be able to re-enter your code. Good Luck!
Old Nov 15, 2008
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
yo dude ill get you your radio code now i am a honda tech and have acces to all the honda stuff ill message you when i get it
Old Nov 15, 2008
Thanks a lot guys, I got the code, you guys rock and this site is the ****
Old Nov 16, 2008
Maverick_1337's Avatar
Maverick_1337 will become famous soon enoughMaverick_1337 will become famous soon enough
https://radio-navicode.honda.com/
Civic15
18
Sep 19, 2017 07:48 PM
mistermenphis22
Jul 13, 2015 04:43 PM
magog45
Jul 9, 2015 06:23 PM
