my radio issue
Old Nov 8, 2008
oscar meza's Avatar
oscar meza will become famous soon enough
my radio issue
well i bought my 04 civic coupe in september
when i bought it everything looked good except the cd player sucks big time. i believe who ever put the wiring in the cd player mest up because every time i press the button for my defroster the radio gets static on every station. do u think its just the wiring because i have never heard of this happening before. another thing is when im listening to a cd i make a fairly normal right turn and then the cd skips....i dont hit a bump or anything it just skips. should i just get a new cd player?
Old Nov 8, 2008
manahoonie's Avatar
Re: my radio issue
sounds screwy....
radio - defroster thing could be something with the rear window wiring stuff.... since our antenna is in the top portion of the rear window (you can see the seperation in 'lines/wires' in the glass itself. the radio antenna is the top 8 inches or so...
so the antenna wires may actually be cracked/broken, causing the static from the heat or pulses coming from the rear defroster...
but as for the right turn thing... i don't know. i'm guessing your radio is aftermarket, since you said that someone installed it and screwed the wiring. did they use a harness? or hardwire/cut wires? got some pics to share of the wiring?
Old Nov 8, 2008
oscar meza's Avatar
Re: my radio issue
no but i will take some i havent really looked into i was just thinking it was a crappy aftermarket radio . . .and i planned on just gettin rid of it and puttin a new one
and i will check the wires in the back as well thanx
i honestly had no idea y it was doing that
Old Nov 9, 2008
ampong's Avatar
ampong has a little shameless behaviour in the past
Re: my radio issue
Hmmm. I will wait the pics on it. It's nice to see this stuff.
Old Nov 9, 2008
Alpha 5's Avatar
Exclamation Re: my radio issue
It is not nice to see this stuff at all. It sucks to know that someone put in an aftermarket radio improperly and now he has to deal with it.
ON TOPIC.
What brand radio is it?
Is it secured in the dash, can you move it around?
Does it skip when you use legit cd's or just burnt ones?
Do you have any other electrical issues with dash lights or anything?
Old Nov 12, 2008
oscar meza's Avatar
Re: my radio issue
sorry i havent put pics up yet havent gotten around to taking them
ummm it skips on all cds only on the right turn. never on the left
the cd player is secure i cant move it around so im still not sure i wanna take it out just waiting till i have time to do it
o and the brand is DUB
yea i know it prob cost the guy like 30 bucks at the swap meet now that i think bout it hahaha
Old Nov 12, 2008
LemmieHill's Avatar
LemmieHill is a jewel in the roughLemmieHill is a jewel in the roughLemmieHill is a jewel in the rough
Re: my radio issue
That whole defroster/static definitely sounds like RFI (radio frequency interference). Its caused by electrical current going through anything (i.e the wires running to the rear heat strips) and becomes prevalent when that current is not isolated through insulation or the antenna wire may have lost its insulation. Taking right turns and making a cd skip, youve got a case of shitty cd player. Does it just skip, or does it cut on and off intermittently? If it was doing that, I might would guess you have a bad ground and when u turn right it moves the wire causing the problem. Id say go for the new cdplayer idea. As for the CEL coming on and off all the time, have u scanned it to see what codes it may be throwing?
Old Nov 13, 2008
electric130's Avatar
Re: my radio issue
do you have a coupe or sedan? i get similar static from my aftermarket head unit when my ebay HID fog lights are on. my OEM low beam HID's don't cause static. only the ebay HID's.
Old Nov 13, 2008
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Re: my radio issue
OK...who the hell still listens to the radio haha. Just get a new unit and attach an ipod to it, no static or commercials.
Old Nov 13, 2008
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
Re: my radio issue
Yeah, sounds like a wiring problem. They probably grounded too much stuff to the same place, and thus, creating a ground loop that interferes with other electronic devices. I've come across situations where static may come from defroster and pressing the throttle, but never steering. Just throw that one out, and have the new one professionally installed.
Black91civic
Jun 6, 2015 08:15 AM
ayoitzjulesdx98
May 13, 2015 08:31 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
avenger
15
Feb 9, 2002 12:14 AM
